Author Topic: Cumulus Plugin  (Read 590 times)
Offline w3mpf
    • W3MPF Weather
Cumulus Plugin
« on: November 18, 2015, 06:10:29 PM »
I am having some issues finding what I am supposed to delete in the cumulus plugin from Ken's site.
I did a "find" in notepad for wdirdata|<#wdirdata>
wspddata|<#wspddata>
I am not sure exactly what lines to delete there is a lot of code and it all just kind of runs together any ideas?
Offline BCJKiwi
    • Silver Acorn Weather - N.Z.
Re: Cumulus Plugin
« Reply #1 on: November 19, 2015, 05:28:43 AM »
You won't need wdirdata nor wspddata unless you want to load those two large arrays and have a way to use them.
From the CU-plugin source file CU-plugin\WXtags-template-files\CUtags.txt file (which is the one Cumulus completes and FTPs to your webserver) delete those two lines if they are there. In the last version of this file they were not in the downloaded file set from Ken anyway.
There won't be a problem if they are there - you will just be uploading un-needed data.
« Last Edit: November 19, 2015, 02:21:32 PM by BCJKiwi »
Offline w3mpf
    • W3MPF Weather
Re: Cumulus Plugin
« Reply #2 on: November 19, 2015, 10:30:24 AM »
Ok thnaks very much. I just didnt want to be using any bandwidth I didnt have to but I did download a very recent version of the plugin so it is probably not there. thanks again.
