Hello,
I'm looking for some weather software that would display data, graphs,etc via the web.
I'm running the Sparkfun Weather board
https://www.sparkfun.com/products/10586 and transmitting data wirelessly via an XBEE module mounted on the Weather Board. The receiving XBEE module logs the weather data into a SQL Server. The problem is that the software I've seen assumes the weather station is connected directly to the PC.
So, any suggestions for software that can pull directly from a database?
Thank you
