Author Topic: Can you use the same power supply on Access as you do for the smart hub?  (Read 571 times)
Offline Broaddd
I imported the wireless bridge, as it was then called I think, to Australia so purchased a power adaptor for it. I see it’s been renamed the smart hub, and I need to replace it with an Access. I was wondering if the Access uses the the same DC plug and voltage, or at least a standard type of DC plug rather than a proprietary one?
Cheers,
b
Offline DoctorKnow
Re: Can you use the same power supply on Access as you do for the smart hub?
« Reply #1 on: February 18, 2018, 03:26:49 PM »
It (access) uses a small camera and phone end style plug, and does not use a round end like the smarthub
Offline Broaddd
« Reply #2 on: February 18, 2018, 03:30:18 PM »
That sounds good, so a suitable wall USB charger and cable should do the trick?
Offline DoctorKnow
« Reply #3 on: February 18, 2018, 03:31:45 PM »
5 volts is all you need, and mine came with a plug.
Offline nincehelser
« Reply #4 on: February 18, 2018, 03:42:25 PM »
Here is a photo of the power adapter that comes with the Access.  It's using a micro USB connector.
