Author Topic: DarkSky info is out of wack after upgrading Meteobridge and Weather34**SOLVED  (Read 857 times)
Offline new2ark
    • AW1401-IP  Home • Weather • Station
i have been using Weather34 and Meteobridge for over a year and this new problem has me scratching my head...check out my website....https://pwsincabotar.com/
« Last Edit: March 14, 2019, 12:03:58 PM by new2ark »
It looks like ./jsondata/wuupdate.php script is missing so none of the external sites data (DarkSky included) is being loaded.
Offline weather34
in meteobridge version wuupdate.php is not part of the forecast the forecast data is driven by mbdbfiles/stationcron.php which is called by meteobridge
<?php
if ($position6=="forecast3ds.php"){
// weather34 darksky  curl based
$url4a 'https://api.forecast.io/forecast/'.$apikey.'/'.$lat.','.$lon.'?lang='.$language.'&units='.$darkskyunit ;
$ch4a curl_init($url4a);
$filename4a '../jsondata/darksky.txt';
$complete_save_loc4a $filename4a
$fp4a fopen($complete_save_loc4a'wb');
curl_setopt($ch4aCURLOPT_FILE$fp4a);
curl_setopt($ch4aCURLOPT_HEADER0);
curl_exec($ch4a);
curl_close($ch4a);
fclose($fp4a);}?>
Offline new2ark
current conditions is now correct....forecast is still wrong
Offline new2ark
3 new files did the trick....thanks for resolving this so quickly
Offline weather34
thank you for highlighting have updated repo with 3 new files for darksky related ..
<?php
curl_exec($ch4a);
curl_close($ch4a);
fclose($fp4a);}?>
Ahh... thanks for that, Brian.  I had been unaware of the move of that code to stationcron from the original wuupdate.
Offline weather34
no problem ken
the reason for that file difference in cumulus etc is I spent so many hours answering emails a few years ago about what is and how to use a cronjob..so i just come up with a dirty solution to kick the necessary files at periods when the template was being browsed , it doesn't do anything unless the site is being viewed it was not a perfect solution but it worked ok and Im not the best explainer of technical methods like cron jobs I guess years of using it you forget to be patient and just do it ..perhaps you might have a cleaner solution specifically for cumulus may be your aware of some function cumulus itself to trigger the file , in meteobridge as you know its just setup the http request in the services tab at whatever interval and thats it ,not sure how it works in cumulus ..
