Author Topic: Choices Choices  (Read 1001 times)
Offline belligero
Choices Choices
« on: October 14, 2019, 06:55:37 PM »
Hi All,
I'm looking into installing a weather camera to go along with my Vantage Pro2 however there are so many options its hard to pick.
Currently I am looking for a POE, PTZ, FTP camera of decent quality. I've been leaning towards HIKVISION DS-2DE2A404IW-DE
I have a few questions which some of you may be able to answer.
- Would this camera be acceptable as a weather camera? I need the PTZ as I have a good vantage point from my roof so would be good to be able to track weather systems by moving the lense.
- Do I need a computer running 24/7 to upload from this camera?
- How bad can heat affect these types of camera's? Being in Australia we have multiple days above 110f.
Hope you can help
Re: Choices Choices
« Reply #1 on: October 14, 2019, 11:07:33 PM »
Here is a link for specs. FYI camera it is a discontinued product. Working Temperature:
-20°C to 60°C (-4°F to 140°F).  Ip66 rated so should work fine as a weather camera.
Most cameras have software for uploading images or you can run a computer and 3rd party software like Blue Iris.
Looks like a decent camera, Hikvision software isn't very user-friendly from my experience. Camera forums will probably have more information.
https://www.hikvision.com/en/Products/PTZ/DE-line-Network-PTZ/4-Megapixel-series/IR/DS-2DE2A204IW-DE3(2.8-12MM)
Offline bchwdlks
Re: Choices Choices
« Reply #2 on: October 15, 2019, 01:50:07 PM »
Hi All,
If you are not sure of what software you want use, or where and what you will do with your images, a easy starting point is to use a Raspberry PI. A lot of the software & interfaces included with cameras are limited in their ability to name the image, keep a library of images, insert timestamps and weather data, or re-size or cut out sections of the image. A RPi is cheap and easy solution for all things related to weather photos.
Re: Choices Choices
« Reply #3 on: October 15, 2019, 02:13:15 PM »
Please share and mention any of your favorite software for image manipulation to run on the Pi?
Offline bchwdlks
Re: Choices Choices
« Reply #4 on: October 15, 2019, 04:52:46 PM »
Imagemagick is the program.
The Meteobridge  web pages have s complete set of instructions with examples on how to use this program for Weather Cam Image Handling.
