Author Topic: WU - Let us know your issues  (Read 187487 times)
Offline Notoriousnick
  • Weathering the changes ...
Re: WU - Let us know your issues
« Reply #500 on: May 08, 2018, 05:25:26 AM »
You're up  =D> =D> =D>
Fine Offset WH-2900 [aka AW WS-2902]
Weathercloud: https://app.weathercloud.net/d4288246333
Offline blakamin
« Reply #501 on: May 08, 2018, 05:32:51 AM »
Lol... looks like WU might take awhile
Stupid text links.
Doesn't help I currently have multiple networks (optus and telstra cellular) until NBN sort their rubbish out for a non-standard install.
Offline blakamin
« Reply #502 on: May 08, 2018, 05:38:53 AM »
I have no idea what you did Nick, but it worked =D>
« Reply #503 on: May 08, 2018, 05:40:23 AM »
I don't know either  :shock:
Are you still on the old firmware or did it actually change?
« Reply #504 on: May 08, 2018, 05:42:15 AM »
In any case, I guess if it ain't broke, don't fix it  :lol:
Offline blakamin
« Reply #505 on: May 08, 2018, 05:42:46 AM »
Still on 1.2.0...  #-o :?
Offline blakamin
« Reply #506 on: May 08, 2018, 05:44:27 AM »
Not going near ambient or ws tool again while data still works!!
Thanks heaps for you time... You at least stopped  me sending it back!  :lol:
« Reply #507 on: May 08, 2018, 05:46:23 AM »
No worries.
I didn't do much though. Things fixed themselves!
Enjoy!
Offline blakamin
« Reply #508 on: May 08, 2018, 06:01:43 AM »
No worries.
Enjoy!
Cheers (now to fix my sig)
Edit: good old html to bbcode converter :D
« Last Edit: May 08, 2018, 06:06:55 AM by blakamin »
Offline WheatonRon
    • WUnderground
« Reply #509 on: May 08, 2018, 08:33:18 AM »
So that no one lies awake at night wondering what the solution is to my problem - I've found it!
Firmware update through WSTools/AmbientTool for my FO WH-2900
In any case, all happy now that WU is working!
Lucky you.. the moment mine connected to weathercloud, all data to WU seemed to stop (already had the fw upgrade) ](*,)
BTW, my station ID is 1 above yours. :)
I experienced the same issue when I connected to Weathercloud.net. When installing the weathercloud module in Weatherlink so I could upload my PWS data to them, it removed my settings to WU! I had to re enter my WU settings in Weatherlink and now everything is fine. This isn’t a WU issue rather either a weathercloud or Weatherlink issue. My guess it is a weathercloud issue. In short, if you sign up for weathercloud, be sure you don’t delete or change settings to others, notably WU. Had I known this, I wouldn’t have start sending my data to weathercloud. I did report this to weathercloud, and they acknowledged my email, so it will be interesting to see if they correct.
« Last Edit: May 08, 2018, 08:47:34 AM by WheatonRon »
Offline DoctorKnow
« Reply #510 on: May 08, 2018, 08:46:14 AM »
Mapbox isn't working properly for me this morning. Icons not loading or real slow to appear.
Offline bdh
« Reply #511 on: May 08, 2018, 11:35:02 AM »
Really squirrely icons do not load then they load and disappear, I am not to happy with them anyway as I have acurite 5-1 and it is mounted 6' high in a totally grassy area with no shade so I get knocked off the map for most of the day as I am surrounded by davies stations now, I even added 2 solar panels to station for east and west cools down fast in evening but still about 3-5  degree higher than davies when it is sunny Also Had to start running firefox just so mapbox worked right code changed this year and they do not support chrome anymore, I just use firefox for weather stuff. :-( :-( :-(
« Last Edit: May 08, 2018, 11:38:39 AM by bdh »
« Reply #512 on: May 08, 2018, 01:23:32 PM »
haven't had a webcam for weeks. Cant find a way to send to WU.
Offline DoctorKnow
« Reply #513 on: May 08, 2018, 03:34:04 PM »
I hope the ones working on the map are trying to get the icons to update live again, like they used to on the google map. I hate the auto refresh interval. I am also seeing the icons currently disappear after loading, and only certain sides of the map are loading at one time.
Offline Intheswamp
    • Beeweather
« Reply #514 on: May 08, 2018, 11:15:53 PM »
Davis VP2, v3.12
Cumulus v1.9.4  Build 1079
www.beeweather.com
www.beausandbonnets.com
Offline Captsalt
« Reply #515 on: May 09, 2018, 06:57:53 AM »
My Ambient WS-2902 logs perfectly to Ambient.net & Weather Cloud site. WU keeps reporting "This PWS is not reporting".
My site: https://www.wunderground.com/personal-weather-station/dashboard?ID=KMOKIRBY9
Please advise what I need to do ... or, is this a WU site issue?
Thank you for any assistance you are able to provide.
« Reply #516 on: May 09, 2018, 07:18:21 AM »
Hi Captsalt,
Copy of my reply to your post in another thread is here:
I had the same thing happen to me.
I then noticed that AmbientTool offered a firmware update (to v1.1.4). I tapped that option and surprisingly, after the update, reporting to WU instantly began and hasn't missed a beat since.
There might be some other reason, but this certainly appeared to be it for me!
Offline Captsalt
« Reply #517 on: May 09, 2018, 08:11:20 AM »
Thanks for the reply. My firmware version: 4.0.0
They're offering 3.0.3
I don't have a clue what to do ... chance it?
Offline WheatonRon
    • WUnderground
« Reply #518 on: May 09, 2018, 08:13:56 AM »
If you just started reporting to weathercloud, that could be the problem. After installing the module for weathercloud, that process removed my WU settings. After that fix, everything is fine.
Offline Captsalt
« Reply #519 on: May 09, 2018, 08:15:16 AM »
Thanks for the reply. How did you make the fix?
Thanks again!
« Reply #520 on: May 09, 2018, 08:35:01 AM »
OK, here down under EasyWeather is used for the firmware, not the one you're using, though the principle may be the same. Could try what WheatonRon is suggesting, though in my case, re-saving the WU settings did not do anything.
Just a hypothesis - the change of firmware to 3.0.3 may help. For EasyWeather I went from 1.2.0 to 1.1.4, which is analogous to your situation perhaps.
Offline WheatonRon
    • WUnderground
« Reply #521 on: May 09, 2018, 08:42:23 AM »
Thanks again!
I am using Davis Weatherlink software so settings for WU for you will be different. When you signed up with WU, they provided you a station ID and a unique password. In Weatherlink, they have a field where to enter this data. When I started uploading to weathercloud last weekend, the weathercloud settings removed my WU settings, so in Weatherlink, I had to re enter my WU station ID (KILWHEAT17, in my case) and password and life is good again.
« Last Edit: May 09, 2018, 09:12:06 AM by WheatonRon »
Offline hazyarc
« Reply #522 on: May 09, 2018, 08:52:10 AM »
Not sure if it's been mentioned, but the email alert when your station stopped reporting after a few hours no longer works (I no longer get an email when my station is offline).
Offline thstaff
  • Founder & Publisher of Blue Ridge Life Magazine - 2005
  • Former TV Weather In Memphis Now In VA Blue Ridge
    • Blue Ridge Life Magazine
Re: WU - Storm App Discontinued May 24th
« Reply #523 on: May 13, 2018, 07:25:38 AM »
Unfortunately it looks like the WU Storm App is completely being phased out. I got a message to upgrade to the Weathwr Cbannel Storm App Version by May 24th. I think the writing is on the wall. They will eventually mothball WU and everything will be merged into weather.com. The weather.com Storm App leaves a lot to desired. It’s more or less an everyday casual weather user. The old app has lots of helpful features.
I went ahead and paid for RadarScope and paid the extra 9 bucks annual fee to get some enhanced features.
Darn shame. WU was a great thing at its peak. They’ve gutted it now and it’s only a matter of time.
Former TV Weather Dude in Memphis Market, (1993-2004) now occasional fill-in in Charlottesville, VA. Co-Founder & publisher of Blue Ridge Life Magazine (2005) near Wintergreen Resort, VA.
Offline Bingo255
« Reply #524 on: May 14, 2018, 04:05:44 PM »
My weather station, KNYCITY12 seems to have vanished from the Wundermap and from my favorites.  How can I correct the problem?
mark
