Author Topic: Low Battery On Station 8  (Read 2466 times)
Offline raldridge
    • Glenorchy
Re: Low Battery On Station 8
« Reply #25 on: November 07, 2017, 12:26:33 AM »
Hi Dalecoy,
As I suspected I had #4 dip switch turned on, so now have turned it off. Then when I went inside again the message was still there. So I put the console into setup mode and while
going through the various things to set up in the Receiving From it had 3 and 8 that it was receiving from, so I checked on each channel which was on and off and channel 8 was the
only the only one that was turned on.
Since going outside and turning the #4 dip switch off and coming back in and re-setting the console that message has not come on again yet.
But in the past it has gone away then to re-emerge again after re-setting the console but after turning the test switch off might just do the trick says me with fingers crossed?.
I have also turned off the re-transmit as per your advice this should save the transmitter battery a bit.
Thanks very much for your help really appreciated.
Offline W3DRM
    • Emmett Weather
« Reply #26 on: November 07, 2017, 12:36:16 AM »
 =D> =D> =D>
--- RIPE Atlas Probe - 32849
Offline dalecoy
    • Lee's Summit, MO
« Reply #27 on: November 07, 2017, 09:36:20 AM »
Sometimes, it's helpful to think about the "simple" things, before diving into the complex ones.
Glad I could help.
Offline raldridge
    • Glenorchy
« Reply #28 on: November 07, 2017, 10:26:23 AM »
Hi Dalecoy,
Unfortunately that message has come back again.
I have written to the people I bought the ISS from hoping their so called scientists can come up with a solution?.
Offline dalecoy
    • Lee's Summit, MO
« Reply #29 on: November 07, 2017, 10:44:59 AM »
Hi Dalecoy,
Consider another new battery.
