Author Topic: Image Rename Script Help **Solved**  (Read 1221 times)
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Image Rename Script Help
« Reply #25 on: October 15, 2017, 05:50:39 AM »
That sort error is because the while loop is not satisfied by any file in that folder, the array is not created and it then doesn´t know what to sort
Offline Ian.
    • Chatteris Weather
« Reply #26 on: October 15, 2017, 08:06:38 AM »
Hi Jachym,
Thanks for pitching in, is it that the script deletes the file before it has been renamed due to an error?
The upload folder does have a file in it, and after running this is deleted.
No newname image is created.
Ian
CWOP - DW3371
PWS - ICAMBRID16
https://www.chatteris.biz
Offline Jáchym
    • Meteotemplate
« Reply #27 on: October 15, 2017, 08:41:22 AM »
I am not familiar with those functions, I would use the "glob" function for scanning the dir content
Offline Ian.
    • Chatteris Weather
« Reply #28 on: October 15, 2017, 09:09:15 AM »
No probs, I'll ask on the forum if anyone will share a working script in case the one I'm using is flawed.
Cheers
Ian
**Solved** the upper case JPG threw the script, all working now, thanks a million to all.
« Last Edit: October 15, 2017, 11:34:32 AM by Ian. »
CWOP - DW3371
PWS - ICAMBRID16
Offline droiddk
Re: Image Rename Script Help **Solved**
« Reply #29 on: October 15, 2017, 02:29:14 PM »
Hi Ian
Marked as solved?
And I agree with Jáchym and will use glob.
This simple script will find jpg's in the folder where the script is and save the latest as image.jpg, can be used with a cron-job.
<?php
if ($images = glob("*.jpg") ) {
   rsort($images);
   $img = $images[0];
   $newfile = 'image.jpg';
   copy($img, $newfile);
Kind Regards
Droid
Offline Ian.
    • Chatteris Weather
« Reply #30 on: October 15, 2017, 02:38:48 PM »
Hi Droid,
Yep all sorted, the script you shared was incredibly useful and I will be using that for another task, the original renaming script is up and running, so I have had a good day...well that was until I asked GoDaddy to migrate my website to a European server and it broke the SSL certificate whichj means I can't send data, so well pi**ed off.
CWOP - DW3371
PWS - ICAMBRID16
Offline droiddk
« Reply #31 on: October 15, 2017, 02:51:56 PM »
Glad it works (the script)  :grin:
Regards
Offline PaulMy
« Reply #32 on: October 15, 2017, 02:54:55 PM »
What changes did you need to make to the script Ian?
Enjoy,
Offline Ian.
    • Chatteris Weather
« Reply #33 on: October 15, 2017, 03:00:23 PM »
Hi Paul,
I compared the original script with the one I was using and the only difference was that the timezone was enabled and I had .JPG rather than .jpg set in one place.
Using your description really helped as I reconstructed it and worked through until it worked.
So many thanks
Ian
CWOP - DW3371
PWS - ICAMBRID16
