Author Topic: Reed switch install  (Read 765 times)
Offline BruceMyers48
Reed switch install
« on: June 23, 2017, 05:15:28 PM »
My vantage pro2  (Used) isn't recording rainfall. I believe maybe the reed switch. I can order one but they look like the wires are soldered to the reed switch. Do wirer's already come soldered to the switch or is that something I will have to do. Thanks
Offline waiukuweather
Re: Reed switch install
« Reply #1 on: June 23, 2017, 05:39:18 PM »
its' likely something you will need to do
as even if you got one with wires re soldered, you would then need to somehow connect those wires to the existing wires (e.g solder)
I recommend putting a some sort of heat sink on the glass end when soldering the wire to the attachment stub
Offline DaleReid
    • Weather at Eau Claire, WI
« Reply #2 on: June 23, 2017, 06:29:21 PM »
They are available from Ryan, I got some a few years back.
ECWx.info
ECWx.info/t/index.php
