Your experience matches my own with the anemometer; I just installed the unit this past Tuesday. I was searching for a suggested lubricant when I found this post. It appears from your video the cup spacing on their older model was greater, and of course there's the whale-looking integrated unit sitting directly underneath it on the 1400... but overall I'm quite happy with the unit. I've read the internal input is just a 2-pin connector and so I can attach any pulse-per-rotation equivalent device to that, so for just $159 for the complete package and $99 to replace an outside unit, I'm ecstatic... I just need to swap the anemometer and I'll keep using the vane as it seems plenty sensitive. I'm considering building a custom acoustic to attach to it (job is sensor design and interface engineering).
The other sensors seem pretty dead on... barometer change of 0.01 absolute, 0.02 relative, and rain gauge gain of 0.967 saw them very close out of the box. That said, I encountered power problems early in a rain storm with receiver and router being dropped three times in quick succession, which caused a substantial over-report of rain; I had them on a UPS in about 5 minutes, deleted 2 data points at WU and corrected rain level in the IP Observer which also updated to WU. Only issue now is my sickly looking wind speed graph.
