Author Topic: NWS (Atom) Alerts for Saratoga Templates PHP 7.1 problem  (Read 3440 times)
Offline n7xrd
    • Beachhouse Weather
Re: NWS (Atom) Alerts for Saratoga Templates PHP 7.1 problem
« Reply #25 on: August 26, 2017, 10:27:57 AM »
php version 7.1 gives this error when there is a Warning appears to run when no warnings are present??  Have made the changes in this thread to no avail.
Warning: Illegal string offset 'WAZ021' in /home/sfiala/public_html/nws-alerts.php on line 308
Fatal error: Uncaught Error: Cannot use string offset as an array in /home/sfiala/public_html/nws-alerts.php:308 Stack trace: #0 /home/sfiala/public_html/header.php(41): include_once() #1 /home/sfiala/public_html/index.php(43): include('/home/sfiala/pu...') #2 {main} thrown in /home/sfiala/public_html/nws-alerts.php on line 308
Offline colonieweather
    • Colonie Weather Online
« Reply #26 on: September 05, 2017, 07:48:27 PM »
I am getting that same error on same line now after going to php 7.1... "Fatal error: Uncaught Error: Cannot use string offset as an array"  and made Ken's recommended changes.  I saw that Curly updated script to fix, but link provided returns a 404.
-Chris
Davis Vantage Pro 2 Plus
WeatherLink v6.0.4
colonieweatheronline.com
Wx Underground - KNYCOLON3
APRS/CWOP - EW0288
Offline CNYWeather
  • Yeah, I'm hugging my traffic light.
    • http://www.cnyweather.com
« Reply #27 on: September 06, 2017, 06:28:11 PM »
I was able to get Version 2.01 off his downloads site
« Last Edit: September 06, 2017, 06:30:11 PM by CNYWeather »
Tony
Offline Curly
    • Michiana Weather
« Reply #28 on: September 06, 2017, 06:36:54 PM »
« Reply #29 on: September 06, 2017, 08:58:32 PM »
Thanks Curly!
It seems to be bombing out on this line:
$logData[] = array($event,$cvk,$effective,$expires,$cis['icon'],$areaDesc,$abbrvDesc);
Got this error:  PHP Fatal error:  Uncaught Error: [] operator not supported for strings
Server is using v 7.1.4
WeatherLink v6.0.4
APRS/CWOP - EW0288
Offline Jasiu
    • LexMAWeather
« Reply #30 on: September 06, 2017, 09:15:44 PM »
I recommend adding a couple of lines of PHP temporarily to see what other (if any) issues you may have.
<?php
error_reporting
(E_ALL E_STRICT);
ini_set("display_errors"1);
I was able to clean up all the PHP 7 issues this way.
Offline tmabell
« Reply #31 on: September 24, 2017, 11:14:18 AM »
EDIT: nws-alerts-log.php  does not work with php 7.1 due to the same issue.
Was this question ever answered directly? "PHP Fatal error:  Uncaught Error: [] operator not supported for strings"
I have this error in conjunction with another script and I'm not clear on how to resolve it.  This is a new issue since migrating to PHP 7.1.
« Last Edit: September 25, 2017, 10:16:59 PM by tmabell »
