It's more pole sway that I'm dealing with when the winds get above 15 mph. It hasn't rained since I raised the height of the pole so I'm not sure if false counts are going to be a problem or not. I may drill through the pipe in two or three spots where the two poles meet and install bolts and nuts to secure the sections together to see if that makes a difference. I have limited space so I'd rather not use guy wire (see attached picture), attaching to the utility pole that's leaning is not an option.
