Weather Related Organizations => CWOP Forum => Topic started by: jordanf9 on July 11, 2018, 08:19:24 AM
I recently registered my stations with CWOP. Both are located in Newfoundland and Labrador, Canada and show up fine on Gladstone and Mesowest. The data however does not seem to be showing up on MADIS or the NOAA mesonet. My call signs/identifiers are EW5388 and FW3242. I registered a week ago today.
Any ideas on when they will show up on MADIS/ NOAA mesonet?
Jordan
Are you talking about these links? The second one you need to select the "observations" tab and then all the networks on the check boxes. Also do 3x at least.
https://madis-data.ncep.noaa.gov/MadisSurface/?CenterLAT=35.075729663136656&CenterLON=-77.71653173828122&Zoom=8
http://www.wrh.noaa.gov/map/?&zoom=9&scroll_zoom=true¢er=35.04573815523954,-77.93426513671875&basemap=ESRI%20Imagery&boundaries=true,true,false&obs=true&obs_type=weather&elements=temp,dew,wind,gust&obs_popup=true&obs_density=10
yeah.. Both stations show up on the second link but not the first (the MADIS one).
It takes a couple days for the metadata to push out after registration.
As of right now (10:14pm Pacific time on July 14) your stations are showing up on MadisSurface. That app has a 600 station display limit so you may need to zoom into the island and only select APRSWXNET from the Datasets panel to see your stations.
Up and running!
Thanks - Jordan
