Skyspy is now running totally on my system.
But . . . .
There still seems to be a problem with the ini file. I did a complete uninstall of the previous version renamed the skyspy.ini file. This was the only file in the folder. Installed the latest version of the server and after installation there was no skyspy.ini file in the folder.
Monitor came up and already had my username and info about skudvrz server. Logged in. No data changed on display. Checked the rest of setup (The rest is from because it's running so nice now, I don't want to go back and mess with it). External display info was default. Mini web contained the settings that were in there from the previous version. Clicked OK. and exited program. Still no skyspy.ini.
Stopped service copy old ini to skyspy.ini. Restarted service and monitor. Started to collect data.
Since there wasn't an ini file in the earlier non service versions, I'm guessing that username, server address and port may have been kept in the registery. I did a search of the registery and could not find the username although there were references to ssServer and ssMonitor.
I had the same problems getting it to report to my database rather than skydvrz. Changed the address when monitor first stared up. Checked in setup the address was still the remote server. Manually changed the server address and clicked OK. Checked ini, changes not included. Stopped server, manually changed ini file and saved it. Restarted service. Everything seems to be working now.
Whew!
