new here,
My PWS is LaCrosse WS3610, uploading to WU via WUHU direct from serial ,
(ie Heavweather is not running).
Uploads are set for every 300 seconds. Rapid Fire is not enabled. That all seems to work fine.
Then I added the station's weathersticker embed to a web page I run,
and I had the page open in a IE browser window here at work.
IT just called and said its averaging 1 hit/second. Is there a tweak I can make,
such as the freq parameter? Needless to say I've removed the code from my webpage.
Here is that embed code provided by WU, with station name snipped:
<object width="290" height="130"><param name="movie" value="
http://www.wunderground.com/swf/pws_mini_rf_nc.swf?station=K<snipped>&freq=2.5&units=english&lang=EN" /><embed src="
http://www.wunderground.com/swf/pws_mini_rf_nc.swf?station=K<snipped>&freq=2.5&units=english&lang=EN" type="application/x-shockwave-flash" width="290" height="130" /></object>
Thanks.
-rj
