I'm posting this under "other hardware" because it could apply to any brand of hardware; I'm using OS hardware in this case.
I keep losing RH sensors. Lost another one a couple of weeks ago. I've got a fan-aspirated solar radiation shield (home-built) with a decent amount of airflow. Even though it is situated over grass, it still manages to pick up a fair amount of dust and dirt, which is hurled mercilessly at my wireless sensor. Eventually, the RH sensor picks up enough dust/dirt that it stops giving accurate measurements.
I've read where you can clean the sensor off and put some hair gel or something on it, but I'm skeptical as to how accurate the resulting measurements will be. So until now, I've just been replacing the sensor with a new one, and I'm starting to get tired of the expense.
Now I've come up with a solution that should fix the problem. It happened in part because I've been playing around with replacing the sensor's thermistor to improve accuracy. You can read about that in this post here:
http://www.wxforum.net/index.php?topic=17353.0Although this is cool, it degrades the sensor's RH accuracy and I wound up purchasing some temperature only sensors (THN132N) and modifying them instead. They actually work a tiny bit better for that purpose anyway.
So that led me to where I placed a second wireless sensor in the fan-aspirated shield to collect RH data since the (improved-accuracy) temperature sensor does not measure humidity.
Then it dawned on me -- the RH sensor does not need to be in the fancy-pants aspirated shield -- it can be nearby in a low-tech naturally-aspirated shield. Both sensors are seeing the same air with the same amount of moisture (i.e. same dew point), even though one sensor may be a few degrees warmer than the other. With this change, the RH sensor won't get pelted with dust and dirt and should have a long, happy life.
The only problem is that I'm reporting temperature (e.g. to internet web sites) from the fan aspirated sensor, but the RH sensor is measuring RH at a different temperature. The dew point from the RH sensor is correct, but I need to adjust the RH number to be correct at the temperature in the fan-aspirated shield. Not a huge problem if you write your own weather logging software
. Or you could just live with the RH errors created by the small temperature difference between the two sensors.
I don't know how many folks will find this useful as it might require some RH adjustments that aren't easy to do in many cases. Perhaps it will give others some ideas...
