Author Topic: Which weather station to buy  (Read 12349 times)
Offline booboo
Re: Which weather station to buy
« Reply #25 on: November 16, 2011, 11:36:18 PM »
(unless you can build one of the wireless connector things described elsewhere on this forum).
How do I find the threads for this?
« Reply #26 on: November 16, 2011, 11:39:00 PM »
Search for posts by "dekay"   A true genius.  Pretty good writer as well.
    • Watts Bar Weather
« Reply #27 on: November 16, 2011, 11:41:20 PM »
Look under Davis Weather Instruments.  Here's an example of a revelent thread:
http://www.wxforum.net/index.php?topic=10315.0
Offline Weather Display
« Reply #28 on: November 16, 2011, 11:42:49 PM »
note that you need to be able to build one your self
or purchase one from SLOWeather (if he has any left or is going to be making more)
I would only be recommending to go down that route if you are good with electronics and can use a soldering iron
Brian
info@weather-display.com
Offline booboo
« Reply #29 on: November 17, 2011, 10:59:44 AM »
Is the weatherlink software any good?  Is it worth $160 for a USB version?  Do they sell the cable by itself?
Offline SLOweather
    • Weatherelement Moline IL
« Reply #30 on: November 17, 2011, 11:22:59 AM »
Not to a USB port AFAIK.  Works for a serial port though.  PM Sloweather for details.
Yup, I have assembled units for sale. (I bought 500 boards from the board house, so I'm not likely to run out any time soon.)
I'll PM him back with the sales page.
Offline SLOweather
« Reply #31 on: November 17, 2011, 11:45:01 AM »
It's OK.
You can find it cheaper. (Call Rob at rainmanweather.com, Unadvertised Sale Price: $108.98, Toll Free: 888.6-RAINWX (888.672-4699))
No.
PMed you ordering info for my serial cable.
« Reply #32 on: November 17, 2011, 12:57:15 PM »
lots of confusion here
there is one version of weather link
there is 2 versions of the data logger (serial or USB)
weather link software comes with the data logger
the package comes with a connecting cable
all this has been covered many times before on this forum ( a forum search will show up results)
Brian
Offline booboo
« Reply #33 on: November 17, 2011, 09:39:48 PM »
Anyone know where I can get screen shots or a demo of Weatherlink?
    • Watts Bar Weather
« Reply #34 on: November 17, 2011, 09:44:12 PM »
google
Offline booboo
« Reply #35 on: November 17, 2011, 09:49:39 PM »
google
Tried that first.  No luck, thanks for your help.
« Reply #36 on: November 17, 2011, 11:45:30 PM »
google
Download a copy from the Davis site.  then use Google to find a .wlk file and play away!
Offline threefingers2
« Reply #37 on: November 19, 2011, 11:36:10 AM »
I plan on purchasing either vantage pro2 or the vantage vue. i guess the cost is the big issue . so it looks like the vue for me. i am wanting to brodcast it on the internet for others to see would you guys have a good software idea?  and also a nice looking home screen with my own weather info? Thanks alot
« Reply #38 on: November 19, 2011, 02:03:35 PM »
not just cost though
you can not as easily separate the sensors with the Vue
there is lots of different software
if you get weatherlink, thats a start point
or use one of the other data logger options noted above (e.g SLOWeather's data logger)
Brian
« Reply #39 on: November 21, 2011, 09:35:25 AM »
Is there any Quality difference between the vantage vue and the pro2 or just the fact that you can seperate the censors? and is the pro 2 worth the extra money?
« Last Edit: November 21, 2011, 09:37:58 AM by threefingers2 »
Offline SLOweather
« Reply #40 on: November 21, 2011, 10:13:57 AM »
The other point is that the wireless VP2 console can receive data from up to 7 more wireless sensors, and that the ISS can be purchased or retrofit with solar and UV sensors, which the Vue cannot.
Offline George Richardson
    • Smith Mountain Lake Weather
« Reply #41 on: November 21, 2011, 10:31:52 AM »
"Is there any Quality difference between the vantage vue and the pro2 or just the fact that you can separate the censors?" I believe the Vue and the VP2 have the same sensors and the same specifications and Accuracy. HOWEVER!
"is the pro 2 worth the extra money?" I think so. To me, mounting the ISS at the proper, maintainable height, ( 5'), and the anemometer higher is important.
I am so glad that when I got my VP2 the Vue was not available. I would probably have purchased it to save a few bucks and been unhappy. If I was starting over today, with my vast knowledge  :roll:, I would buy the VP2 only, mount it on a fence post and start looking. You will need a datalogger and a couple are available on this forum. I have purchased 3 Davis Weatherlink units from ebay ( I have 1 shrink wrapped left ) for $75 -$85. After the Datalogger, I would get Cumulus software (donationware) and start accumulating data.
Now you can start deciding on a permanent location for your equipment. My local mounting probably cost around $100. You can do it for less, if you remote mount anemometer it will be more. The thing is, you don't have to do it all at once.
FWIW
George
« Reply #42 on: November 21, 2011, 11:04:24 AM »
Fleabay's lowest price on the logger is !$150
« Reply #43 on: November 21, 2011, 11:45:40 AM »
"Fleabay's lowest price on the logger is !$150"
One sold yesterday, NEW, for $47! (http://www.ebay.com/itm/350506763606?ssPageName=STRK:MEDWX:IT)
I didn't say every day, all the time. I said wait and watch.
FWIW
George
« Reply #44 on: November 21, 2011, 06:41:22 PM »
Thankx alot guys i just look at the vue on e-bay at 289.00 and 550.00 for the pro2 and wonder how if i would add more sensors ,probly not, but having it seperated  with the temp closer to the ground intead of having the roof heat affect it makes more sence.
Offline SLOweather
« Reply #45 on: November 21, 2011, 06:53:11 PM »
You can get a Vue from rainmanweather.com for $257.95, a wireless VP2 for $385.99, or a wireless VP2 Plus with solar and UV for $635.98.
Call Rob and ask for the unadvertised price, or go to the website and create an account to see the special pricing.
« Last Edit: November 21, 2011, 06:55:13 PM by SLOweather »
« Reply #46 on: November 22, 2011, 10:08:33 AM »
Hey thanks alot for your help SLOweather i will have to check into it mayby i might be able to get the pro2. Again thanks for the info.  =D>
« Reply #47 on: November 24, 2011, 07:45:04 PM »
Well guys i took the plunge and ordered the Vantage Vue. I talked it over with Rob at Rainman Weather and told him about my yard space and other things and he suggested the vue would work better for me. So i went to Menards and bought the pole and the antenna tripod and mounted it up on my garage roof in waiting for the UPS man to pull up on the 30th. I also bought the IP version so i can brodcast it on a weather site.   \:D/  I'm thinking i might have to come back on here and ask how and the heck to get this up and running but i'll give it a go.
« Last Edit: November 24, 2011, 07:47:10 PM by threefingers2 »
Offline d_l
  • Slide Mtn - Mt Rose
« Reply #48 on: November 24, 2011, 07:54:19 PM »
You should read the manuals for the Vue and the Weatherlink, prior to the UPS arrival: http://www.davisnet.com/support/weather/support_docs.asp?dtype=1  That way you will know what you will need to do for the set up and assembly of the Vue and IP logger.
There will be a pop test on them on Monday.   ;)  :lol:
« Last Edit: November 24, 2011, 07:57:25 PM by d_l »
--Dave--
    • Watts Bar Weather
« Reply #49 on: November 24, 2011, 08:16:50 PM »
Atta boy!   =D>
I'm sure you'll like it.  I don't know much about the IP thing, but I know that we'll all give you plenty of moral support!   =D> =D>
