Author Topic: How to scrape WU data and use it in a php script  (Read 1818 times)
Offline MikeWest
    • Observatory West
« on: December 23, 2017, 08:43:50 PM »
Hello,
I have an Ambient Weather WS-2902 that sends to WU, AW.net and weathercloud.  I am trying to put together a php based weather website from Saratoga or similar, however I cannot figure out how to scrape the data from my WU station ID and make it available to php?  I have searched, read many many pages, and not found anything that seems like it would work, short of buying something like Weather-Display software.  Is there anything out there that is free and works?
So many trees in NJ!
Offline Maumelle Weather
    • Maumelle Weather
Re: How to scrape WU data and use it in a php script
« Reply #1 on: December 23, 2017, 08:56:30 PM »
Check here:  Sandaysoft Home of CumulusMX software
GR2AE, GR3, Cumulus
Offline SteveFitz1
    • Tyler Texas Weather
« Reply #2 on: December 23, 2017, 10:02:15 PM »
If you're simply wanting to "scrape" your own data from Wunderground, you should consder using a WU API to pull the information directly into PHP variables you can plug into your own webpage. https://www.wunderground.com/weather/api/d/docs?d=data/conditions#examples
You'll first need to get an API key from WU, then plug it in here along with your WU Station ID to see what information is provided:
http://api.wunderground.com/api/---Your WU API Key---/conditions/q/pws:---Your WU Station ID---.json
Steve
Offline MikeWest
    • Observatory West
« Reply #3 on: December 23, 2017, 10:25:08 PM »
Thanks Steve, I do already have an API key, and using your sample below I have it spitting out the information, now I need to figure out how to push that into something usable by one of the templates. Do you know of a reliable way to translate the json information into an appropriate realtime.txt file?  It seems to me now that I would need a CRON job or equivalent running every so often to pull the info, a second job running right after to translate the info into a suitable realtime.txt file, then the normal template files would take over to display the information.
Thanks for your help!
Steve
Offline SteveFitz1
« Reply #4 on: December 23, 2017, 10:32:07 PM »
PM me with your email address and I'll send you a script I use to pull info.
Steve
Offline MikeWest
    • Observatory West
« Reply #5 on: December 23, 2017, 10:36:29 PM »
I just PM'd you, thanks!
Steve
