I have been using meteobridge with a ObserverIP and Ambient WS. It has worked fine. I was thinking of adding a Rainwise to the equation, with either CC-3000 or IP-100 (if Boris cracks the codes). The question is whether the meteobridge can read both units and can one select which sensors to use to publish to different selected weather services. There seems to be some inferrence that one can turn on or off sensors on the Live Data tab? Since the Rainwise does not have illimination or UV, and Ambient does, it would be nice to combine both.
