I've an Ambient "WeatherHub4" that I can't seem to get a WiFi connection with. The USB dongle lights as if transmitting but it appears not to be. With it connected by Ethernet it seems to run maybe 12 or so hours and then disconnect. I can no longer access the hub from it's IP with out a reboot using the power button or removing the DC power The switch it's connected to is a 120V powered commercial device that I have no other issues with.
I would certainly like to use the "wireless" aspect vs. maybe relocating the VP2 console, the USB hub (the supplied Belkin), the USB WiFi dongle is the DWA-131 also supplied with the hub. I have 5.0i update.
I'm not familiar enough with this to know if there's information in the logs that might help me correct my issues.
