I am a firm believer in the value of using Meteohub on a RaspberryPi with a Meteostick for retrieving data from a DVP2. It's an elegant way to capture data from the VP2 (docbee says a 16G uSD card will hold about 10 years worth of data) as well as send the data to your website of choice. You can also graph data from the Hub and send data to SQL dbs. What's cooler than that?
However, the Meteostick option comes with a bulbous USB cable that can be eliminated with a compact USB Up connector. Mine cost a paltry $US 6, shipped! It works great and allows a little better antenna placement. The only problem is that I can't see the ethernet ports data lights now, although they are winking as usual.
