Hi folks, just purchased a Davis 6152 a few weeks ago. I am curious about a couple things that maybe someone here can answer for me.
First, during daylight hours does the ISS solar panel store any energy for nighttime hours..... or does the ISS switch to the CR123 lithium as soon as it quits receiving sunlight energy?
Secondly, I live in Manitoba Canada where winter temperatures and conditions can be quite brutal. Is it ok to just leave the rain collector funnel uncovered during the winter months? I am wondering if the snow buildup and subsequent melting/freezing will damage the rain tippers.... or if they will simply just freeze solid and then thaw out in the spring?
And third, I am planning to install a 2nd Davis 6152 at another location in a few days, and plan to mount it on the roof peak with a 10' pole. Since I am putting both ISS and anemometer on the same pole, is it recommended to place both components at the very top of the 10' pole, or should i keep the ISS perhaps in the middle of the pole for easier access?
Thanks for any comments or suggestions you guys might have.
