I'd go with the failed super cap.. but also check the solar panel, that it is charging the super cap. I found the below information on the ISS and console, I'd check the solar panel and also check that the test switch on the dip switch on the ISS board is in the off position... that can drain both if not in the off position. That can happen... maybe gremlins but it is also worth a check.....
the specs:
Integrated Sensor Suite (ISS)
Operating Temperature . . . . . . . . . . . . . . . . . . . . . . . . . .-40� to +150�F (-40� to +65�C)
Storage Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . -50� to +158�F (-45� to +70�C)
Current Draw (ISS SIM only) . . . . . . . . . . . . . . . . . . . . . . 0.14 mA (average), 30 mA (peak) at 4 to 6 VDC
Solar Power Panel (ISS SIM / Fan-Aspirated) . . . . . . . . . . 0.5 Watts / 0.75 Watts
Battery (ISS SIM /Fan-Aspirated) . . . . . . . . . . . . . . . .. . . CR-123 3-Volt Lithium cell / 2 - 1.2 Volt NiCad C-cells
Battery Life (3-Volt Lithium cell) . . . . . . . . . . . . . . . . . . . . 8 months without sunlight - 2+ years on solar
Battery Life (NiCad C-cells) . . . . . . . . . . . . . . . . . . . . . . . 1 year
Fan Aspiration Rate (Fan-Aspirated Only) . . . . . . . . . . . . 190 feet/min. (0.9 m/s) (full sun), 80 feet/min. (0.4 m/s) (battery only) (intake flow rate) 500 feet/min. (2.5 m/s) (full sun), 280 feet/min. (1.4 m/s) (battery only) (sensor chamber flow rate)
Connectors, Sensor. . . . . . . . . . . . . . . . . . . . . . . . . . . . . Modular RJ-11
Cable Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-conductor, 26 AWG
Cable Length, Anemometer . . . . . . . . . . . . . . . . . . . . . . . 40' (12 m) (included), 240' (73 m) (maximum recommended)
Wind Speed Sensor . . . . . . . . . . . . . . . . . . . . . . . . . . . . Large wind cups with magnetic switch
Wind Direction Sensor . . . . . . . . . . . . . . . . . . . . . . . . . . Wind vane with potentiometer
Rain Collector Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . Tip bucket, 0.01" per tip (0.2 mm with metric rain adapter), 33.2 in2 (214 cm2) collection area
Temperature Sensor Type. . . . . . . . . . . . . . . . . . . . . . . . Thermistor
Relative Humidity Sensor Type . . . . . . . . . . . . . . . . . . . . Film capacitor element
Housing Material . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . UV-resistant PVC plastic
Console
Console Operating Temperature . . . . . . . . . . . . . . . . . . . +14� to +140�F (-10� to +60�C)
Display Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . . +32� to +140�F (0� to +60�C)
Storage Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . -5� to +158�F (-20� to +70�C)
Current Draw . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.90 mA average, 20 mA peak, (plus 120 mA for display lamps, plus 0.125 mA for each optional wireless transmitter received by the console) at 4 to 6 VDC
AC Power Adapter. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 VDC, 900 mA, regulated
Batteries . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 C-cells
Battery Life . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . up to 9 months
Connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Modular RJ-11
Console Display Type . . . . . . . . . . . . . . . . . . . . . . . . . . . LCD Transflective
Dimensions (console: length x width x height; Display: length x height)
Console with antenna . . . . . . . . . . . . . . . . . . . . . . . 10.375" x 1.5" x 6.13" (264 mm x 38 mm x 156 mm)
Console with antenna extended up . . . . . . . . . . . . . 10.375" x 1.5" x 9.8" (264 mm x 38 mm x 248 mm)
Display . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.94" x 3.375" (151 mm x 86 mm)
Weight (with batteries) . . . . . . . . . . . . . . . . . . . . . . . . . . 1.88 lbs. (.85 kg)
