Author Topic: Telescoping flagpole as anemometer mast?  (Read 23935 times)
Offline d_l
  • Slide Mtn - Mt Rose
« on: November 17, 2011, 05:24:36 PM »
I know that a telescoping flagpole has been suggested as an anemometer mast in the past, but has anyone actually used one and what are your opinions? This would be for a VP2 anemometer and not the larger, heavier Vue.
I have a very solid gable mount from my old Digitar days, but due to some spinal problems and landscaping vegetation below it, I probably can't place my 22' A1 ladder to install an anemometer up there without injuring myself.  I guess I could hire out someone to do it or bother a neighbor for help, but often times these installations aren't one-shot deals.  Sometimes they need to be serviced after a failure.
So I've been investigating the possibility of using a telescoping aluminum flagpole as a 20-ft anemometer mast.  My concerns are how much sway might be expected in winds up to 80 mph, how much vibration in those winds can be expected from play in the telescoping segment joints, and would all this affect the wind measurements.  I've looked at video demonstrations of various flagpole's operation with flags on them, but it doesn't seem that they were emphasizing their rigidity in the videos.
Also some poles have a twist and lock mechanism which seems that it would twist the alignment of the anemometer off of north as the pole is raised.  I think the alignment could be twisted back to north by rotating the pole base, but on some poles there is no locking mechanism in the ground sleeve.  This might allow the pole to twist due to wind torque on the anemometer arm.
So I've considered the following for telescoping flagpoles:
Advantages:
  • Relatively easy installation compared to my gable mount
  • Easy to collapse mast for anemometer servicing
  • 20' will be higher than the mast I once had on my gable mount (17')
  • Avoidance of roof top wind turbulence
Disadvantages:
  • Price
  • My limited placement options to avoid blocking my weather cam view or to minimize wind obstructions from trees and other houses
  • Possibility of sway/vibration affecting measurements
Various flagpole dealers are claiming their aluminum poles are stronger than equivalent steel gauges and that their poles can hand 80-90 mph winds with 3x5 flags attached.  This dealer seems to have the best price for what is offered, longest warranty, strongest aluminum, and the thickest pipe gauge of any I've seen: http://tele-pole.com/superior.html
If I buy a pole and it doesn't work out for an anemometer mast,  I guess could always move it to the front yard to be a flagpole.
« Last Edit: November 17, 2011, 09:01:31 PM by d_l »
--Dave--
Offline kjf101
Re: Telescoping flagpole as anemometer mast?
« Reply #1 on: November 18, 2011, 07:40:56 AM »
Offline d_l
« Reply #2 on: November 18, 2011, 10:04:57 AM »
I am sure it will work, check this out by Rainwise.
Thanks for that link.  It looks like the Rainwise mast has swedged aluminum pipe joints.  I don't know if those pipe joints would be stiffer than telescoping joints and have less sway, but I'd think flying a flag on that mast in high winds wouldn't be feasible though.
--Dave--
Offline PatrioticRick
  • USAF Retired
    • WeatherLink
« Reply #3 on: January 02, 2012, 06:34:33 AM »
I have had many flag poles in my life and one thing I know is:  In the wind they move! Regardless of if there is a flag on them, because they have no guy wires to stop the movement.  Once I had one of those sectional flag poles with a 3'X5' flag on it and it looked like a fly rod in wind, I took it down and made my own out of 2" schedule 80 pipe 31' tall two peices welded together weighs about 200 lbs and supports a 5'X8' and a 3'X5' flag with no problems, but the pole still moves even with no flags on it, in the wind.
CWOP=DW9069
MADIS=D9069
WU=KIDRIGBY2
PWS=RIGBYWX1
WxBug=p19372
WOW=373047692
Davis VP2 6152 w/WeatherLinkIP
WeatherLink 6.0.3
Offline d_l
« Reply #4 on: January 02, 2012, 10:25:13 AM »
So far my experience is that a 25-foot telescoping flagpole made by TelePole, the manufacturer listed above, has shown at most about one foot or so of sway in 45 to +50 mph gusting winds (30-40 mph sustained) with just an anemometer and the standard gold ball on it.  The sway is due to play in the telescoping joints and not from flexing of the individual pipe segments.
As far as I can tell at this time, this degree of sway doesn't seem to appreciably affect the accuracy of wind speed and direction measurements; however, the ball atop the pole might have some influence on the lower wind speed measurements.  This will be watched and tested in the future.
I doubt that most people's generally low opinions on the stiffness and rigidity of telescoping flag poles were formed by observations on the Superior 1 model flag poles manufactured by TelePole.  These poles are the only 10 gauge poles on the market and have only been offered for sale over the last few years.  The more common, cheaper 13-16 gauge poles sold by everyone else would be the poles typically seen flexing in the wind like fly rods.
It should be noted that the 25-foot Superior 1 pole only weighs about 21 pounds which makes it very manageable compared to other heavier mast options suggested here at wxforum.
--Dave--
Offline Wx4U
« Reply #5 on: January 02, 2012, 10:22:10 PM »
I'm using a Channelmaster TV antenna telescoping pole. I do have guy wires on it. Probably the max wind it has withstood is around 60 mph. No problems. I have a 4"X4"X6' post in the ground, then clamped the telescoping pole to it. It can be turned to set the correct direction. Guess it has been up over two years. Make sure you add a good ground.
Retired USAF Air Traffic Controller, Davis VP2 Wireless, WLS 5.8.2, LaCrosse 2308, Logitech Pro 9000 (Roof mounted on rotor), CoCoRaSh gauge, KTXARLIN35, Compaq Presario W/Vista
Offline WeatherHost
« Reply #6 on: January 03, 2012, 09:46:01 AM »
How did you raise that to vertical?  We had a discussion about that on another thread not too long ago.
Offline Skywatch
« Reply #7 on: January 03, 2012, 12:47:12 PM »
My pole is made from galvanized steel and stands at 25 Ft it does sway about 6 inches in moderate wind conditions (10-15 mph) but doesn't rock untill we hit 40mph and we hardly ever see anything over 50mph. But I would gess it would be about 60mph before we see any damage to the pole. I have the pole lashed at 10 ft above that it's on it's own.
When fully extended how much pipe is left unextended or inside the lower pole section? I would think the closer you have the 2 ends together the more instable it would be.
I am a storm chaser.
  • USAF Retired
    • WeatherLink
« Reply #8 on: January 05, 2012, 12:16:13 AM »
made my own out of 2" schedule 80 pipe 31' tall two pieces welded together weighs about 200 lbs
Three ropes, one tied to my truck to lift it and the other two held by myself and a neighbor to guide it up and into a socket, as the truck backed up slowly it raised, once vertical dropped in a socket with a little help from my daughter making sure it didn't slide.  Took two trys first time fell to one side into a tree.  OK so I'm not an artist, but here it is.  :oops:
Flagpole0001 by PatrioticRick, on Flickr
Garfield Area looking East to 3700E by PatrioticRick, on Flickr
Ben up for about eight years now.
« Last Edit: January 06, 2012, 04:25:15 AM by PatrioticRick »
CWOP=DW9069
MADIS=D9069
WU=KIDRIGBY2
PWS=RIGBYWX1
WxBug=p19372
WOW=373047692
WeatherLink 6.0.3
Offline wuhu_software
    • WUHU Software Yahoo Group
« Reply #9 on: January 20, 2012, 05:03:47 PM »
Harbor Freight sells a couple of them pretty cheap.
http://www.harborfreight.com/catalogsearch/result?q=telescoping+flag+pole
I will probably give one a try as I cannot access the roof top during the winter months.
Offline d_l
« Reply #10 on: January 20, 2012, 06:32:12 PM »
I wouldn't advise getting a flag pole thinner than 10 gauge if you have winds higher than 40 mph.  Even a 10 gauge pole flexes a bit in those winds, but I'd be afraid of a thinner walled pole possibly folding over in +40-50 mph winds.
--Dave--
« Reply #11 on: January 21, 2012, 09:53:15 AM »
Since these poles are not holding a flag, I think 40+ mph speeds should not be an issue. If it is affixed to a house, you also devise a scheme using a bracket or wires to stabilize the pole so that the flex is minimized to the last section or two.
Offline WeatherHost
« Reply #12 on: January 21, 2012, 10:08:42 AM »
I've got two pieces of 3/4" conduit strapped to a 17G fence top rail (effectively 3 small masts lashed together to make one multi-core mast) and it would flop around like a dead herring if it wasn't guyed and attached to the back of the garage.  But at least I can lower and raise it without too much trouble.
Offline d_l
« Reply #13 on: June 07, 2012, 02:18:46 PM »
As a follow up to this thread, I installed a Davis 6382 Temp/Hum station and connected it to the Davis anemometer transmitter with 25 feet of 6 wire phone cable to make a partial ISS.  I thought that the radiation shield of the 6382 might cause excessive sway in high winds so I guy wired the flagpole.  A bit of my 12-foot high anemometer can be seen on the extreme left of the photo.  Since I added the temp/hum sensor and guy wires, it has registered a 64 mph peak gust.
--Dave--
Offline tsharac
« Reply #14 on: June 08, 2012, 09:10:33 AM »
Looks great!
What gauge guy wires did you use? How far away from the mast are the guy wires anchored?
Offline d_l
« Reply #15 on: June 08, 2012, 10:55:42 AM »
I felt this particular pole's pipes at 10 gauge could handle the wind load unassisted if necessary, but that the constant flexing play in the sliding joints could wear them over time.  So I used 1/8" clear coated, guy wires to steady it.  I think I could easily have dropped that to 3/32" and still had enough strength in the wires.  The load strength of the wires was rated at about 90 lbs., but I thought that I might have to make several trial-and-error attempts at setting the clamps and thimble hardware on each line to be within the turnbuckle's tightening range.  I was right. So each wire has several pinch spots from incorrect clamping attempts that reduce its load strength.  Really, a lot of my choice in wire size was determined by the size of clamps and turnbuckles the hardware store had available.
The three wires aren't exactly at a 120 degree separation angle around the pole, but were placed to minimize the likelihood that they would be a path obstruction in the natural vegetation behind the wall. They also are oriented to cover the strongest wind directions.  The wires are about 30-33' long attached to construction stakes driven into the ground.  The ground is quite rocky back there so finding a place to drive them in was more important than the exact distance (roughly 15-16') from the pole base.  The attachment angles at the top and bottom are therefore very roughly around 30 and 60 degrees respectively.
The top wire thimbles are hooked to several of the flagpole's carabiners which are then hooked to the top rotating swivel hardware normally used for a flag.  The manufacturer claims that this hardware is made of carbon fiber so it should be a strong enough and durable attachment point.
I think a cheaper model flagpole with thinner gauge walls could be used like this as long as dependably strong guy wires were attached to it.  Although the Lexan flag swivels of the cheaper poles might not hold up well as an attachment point over time.
--Dave--
Offline d_l
« Reply #16 on: June 14, 2015, 06:03:40 PM »
As a follow up, very long term report on the use of a Tele-Pole Superior 1 for an anemometer mast,  I found that the flag attachment swivels I used as guy wire attachment points can snap off when the turnbuckle hardware for one cable unscrewed allowing the pole to whip and snap during high wind (+60mph).  After obtaining a warranty replacement from Tele-Pole, I fashioned reinforcement sleeves for the swivel rings.  Over the past few years, there have been multiple wind gust events in excess of 65 mph.  The top of the pole barely moves more than an inch and the swivel rings have held up to the buffeting.
Because I already had temperature, humidty, and wind on this station, I decided to go whole hog and make it a back up and a full "high" conditions station by adding a solar sensor and a rain gauge.  The mounting method I used for attach ther solar sensor to the flag pole was novel.  Some of the construction details and detailed pictures of various aspects of this second station can be found at my website if you are interested: http://www.tceweather.com/TCE26.html.  I'd have posted the photos here but they are large and would blow the bandwidth of the site and also posted photos seem to disappear over time here.
--Dave--
« Reply #17 on: June 14, 2015, 07:48:58 PM »
3 years, thanks for the follow up.  =D>
I've got 8 months on a 30' superior 3 without guy wires and so far so good. Survived 3 different 50 mph winds and it does sway, but that's OK with me.
Offline d_l
« Reply #18 on: June 14, 2015, 09:48:41 PM »
Randy, if you just have an anemometer on that Superior 3, then I can see that it certainly wouldn't need guy wires.  Any idea how much the top moved during those gusts?
Once I put the extra weight and wind resistance of the temp/hum sensor on top of my pole, I knew it would be best to stabilize it with guy wires.  There are some interesting inversion conditions here at times that my "high" station reveals.
--Dave--
Offline wxtech
    • Lexington, Ga. Weather
« Reply #19 on: June 14, 2015, 10:08:56 PM »
I've been using the sectional aluminum Valley Forge Model # AFP20F flag poles for wx eqpt many years without guy wires.  I have a Davis anemometer at the top.  It is light weight so that I can install or take down by myself when wind is calm.  I use an 8' galvanized chain link fence post in the ground.  The aluminum mast fits inside the steel tube.  A picture is attached showing my current installation but now it is taller with 4 sections.  The photo is dated April 29, 2011.  It does not sway in winds.  I purchased the kit from Lowes (with flag).  The sections are not bolted.
I have another pole with flag at the front of my house.
« Reply #20 on: June 14, 2015, 10:27:53 PM »
I'm guessing 12". No extra weight with anemometer only but I did add an extension to get 33' but its light gauge aluminium less than 2 lbs.
https://www.flickr.com/photos/100354683@N03/17963539106/in/photostream/
Offline wagz4me
« Reply #21 on: October 01, 2015, 05:14:07 PM »
Hi everyone,
I too have purchased a telescoping flagpole for my anemometer because I cannot get up on a ladder easily anymore.  Like several other members here, I felt that it would make for easier maintenance for me, requiring only a 6 foot ladder.  My pole will be about 20' high above ground, with about 3 feet buried, and will be secured to a 5' wooden fence post (8' post, about 3 feet buried).  The only thing on the pole will be the anemometer (Davis, plastic).  This location is about 12' or so from the corner of my house (which is concrete block and grounded), and is nowhere NEAR the highest object in my subdivision.  Although it will be up high enough to clear the rooftops for reasonable readings, it's not as high as the 40-50' pine and palm trees in the woods behind me, or as high as the electrical poles on the road behind that woods.  I am not sure if I should ground this pole or not, being that the pole and the post are so far down in the ground.  I am in Florida, aka the lightning capital of the world, but have never taken a hit anywhere close to my place in the 36 years I've lived here (many different places over that time period!)  I am considering grounding this pole, but not sure if I need to ground it, and don't know how long the grounding rod should be (I've never done this before!)  Any suggestions on this?  I hope this is not a dumb question, but...I will ask anyway :-)  I always appreciate your comments and input, have a good afternoon everyone!
--Carol
Carol:)
« Reply #22 on: October 01, 2015, 06:01:17 PM »
Hi everyone,
--Carol
I'm no electrical engineer, but if the pole is a good conductor, 3' should be plenty deep enough as a good ground.
« Reply #23 on: October 01, 2015, 06:26:05 PM »
I read somewhere as long as the mast isn't attached to the house and goes directly into ground, no grounding would be necessary. I can say the telepole 30' version which I have had no instructions to add any grounding device.
What I'm not 100% clear on if wire from example camera or anemometer coming into home could become a current path? Possible it would go least resistance directly into ground through flagpole base and not follow wire.
« Reply #24 on: October 01, 2015, 06:49:16 PM »
I think that's an absolute possibility, dare I say probable, that current would not only follow the pole, but into the house. Discharging millions of volts and hundreds of thousands of amps, I would never presume that ALL of it would be grounded with such an easy path into the house also.
