Author Topic: Wxadvisory.php error fetching or reading data  (Read 2258 times)
Offline JohnN
    • Monmouth County Weather
« on: March 31, 2014, 02:44:36 PM »
When I access my wxadvisory.php page, I get an error message that says: Advisory Information Unavailable, error fetching or reading data from the NOAA advisories server. Does anyone have any suggestions? http://monmouthcountyweather.com/weather/advisories/wxadvisory.php
www.monmouthcountyweather.comUK Met Office: 45560463
Twitter: @John_N_WxCoCoRaHS: NJ-MN-64
CWOP: E1682Davis Vantage Vue, Pro2Plus w/24 hr FARS, Ambient Weather WS-1000
PWS/WFY: SOUTHARDNJCumulusMX
Wunderground: KNJHOWEL11
                       KNJHOWEL15
LiveATC: KWRI/KNEL/New York Center
             KMJX/KBLM/3N6/N12
Offline W3DRM
    • Emmett Weather
Re: Wxadvisory.php error fetching or reading data
« Reply #1 on: March 31, 2014, 03:26:27 PM »
Are you running the latest version of the advisory scripts? There was a change made by Ken back on March 15th.
--- RIPE Atlas Probe - 32849
Offline JohnN
« Reply #2 on: March 31, 2014, 03:37:09 PM »
I downloaded the version from Saratoga-weather.org, which says it was last updated Nov 2011. I guess I have to find the newest version now.
                       KNJHOWEL15
             KMJX/KBLM/3N6/N12
Offline W3DRM
    • Emmett Weather
« Reply #3 on: March 31, 2014, 04:13:00 PM »
I see a new "advforecast2.php" file with a date of 3-17-2014 on it. That was the date I uploaded the new file I had downloaded from Ken's Saratoga Weather site. That file contains the following version notes:
//  Version 3.11 - 13-Mar-2014 - fixed point forecast text non-display due to NWS website changes
//  Version 3.12 - 15-Mar-2014 - fixes for Zone forecast, warnings and auto-correct old URLs
$Version = 'advforecast2.php (multi) - V3.12 - 15-Mar-2014';
I seem to remember having URL problems which resulted in the advisories not being displayed.
Looking further at Ken's website, it appears this change impacted Base-USA templates so I don't know whether it is applicable to your site or not.
« Last Edit: March 31, 2014, 04:17:48 PM by W3DRM »
Offline JohnN
« Reply #4 on: March 31, 2014, 04:17:17 PM »
I downloaded the advforecast2 page today. The problem I'm having is with the Advisories page, not forecast.
                       KNJHOWEL15
             KMJX/KBLM/3N6/N12
Offline JohnN
« Reply #5 on: April 03, 2014, 11:54:06 AM »
Anyone? I'd like to get this fixed, if the problem is on my end.
                       KNJHOWEL15
             KMJX/KBLM/3N6/N12
« Reply #6 on: April 03, 2014, 12:25:11 PM »
Since you've modified the atom-advisory.php script (or hidden it behind your wxadvisory.php page), I can't remotely diagnose what is happening.  Please post the source of the page (and the atom-advisory.php you're using) in order to see what's going on.
I tested the NJZ013 zone with my (unmodified) script, and it returns
There are no active watches, warnings or advisories for Western Monmouth (New Jersey).
Best regards,
Ken
Offline JohnN
« Reply #7 on: April 03, 2014, 12:38:50 PM »
Attached is the atom-advisory page (only modifications were renaming it to wxadvisory.php and adding the dropdown menu). I have tried it both with and without the dropdown menu, and have gotten the error both times. I changed the file to .txt, so that I can upload it here.
                       KNJHOWEL15
             KMJX/KBLM/3N6/N12
« Reply #8 on: April 03, 2014, 01:41:40 PM »
There is something strange going on .. I see the changes you made to the source, but that wouldn't change how it works (or doesn't work at present).
I ran my script with ?cache=refresh to force a cache reload and the view-source of the page showed the expected
<!-- atom-advisory.php - atom-advisory.php - V2.09 05-Nov-2011 -->
<!-- getting new file from http://alerts.weather.gov/cap/wwaatmget.php?x=NJZ013 -->
<!-- CURL GET /cap/wwaatmget.php?x=NJZ013 HTTP/1.1 Host: alerts.weather.gov -->
<!-- Time to fetch: 0.266 sec -->
<!-- cache saved to ./atom-advisory-NJZ013.txt -->
<p>There are no active watches, warnings or advisories for Western Monmouth (New Jersey).</p><!-- zone=NJZ013 -->
Doing the same with your script on your server returns just
If no warnings are listed, try selecting "Monmouth County" or "Ocean County".<p>Advisory Information Unavailable, error fetching or reading data from the <a href="http://alerts.weather.gov/cap/wwaatmget.php?x=NJZ013">NOAA advisories server.</a></p>
with none of the other debug stuff.
Trying your code on my server with ?cache=refresh shows
<!-- wxadvisory-johnn.php - atom-advisory.php - V2.09 05-Nov-2011 -->
<!-- Time to fetch: 0.276 sec -->
So I'm suspecting that the problem is with cURL on your webserver (either not installed, or not configured to allow HTTP access).
You can change the line
   if (!function_exists('curl_init')) {
to
   if (true or !function_exists('curl_init')) {
to force the script to use the built-in function to retrieve the data (and not use cURL).
See if that works for you...
Best regards,
Ken
Offline JohnN
« Reply #9 on: April 03, 2014, 05:39:16 PM »
I'll try the change, if I can ever get access to my website again... Every time I try to connect, my FTP client has been timing out. Maybe one of these days I'll upgrade to a better host.
                       KNJHOWEL15
             KMJX/KBLM/3N6/N12
Offline JohnN
« Reply #10 on: April 26, 2014, 02:14:26 PM »
I finally got around to making the change, but it is still giving me the same error. I'll upload the current file here.
                       KNJHOWEL15
             KMJX/KBLM/3N6/N12
