Weather Related Organizations => WeatherUnderground => Topic started by: ggsteve on December 30, 2014, 06:05:57 PM
Title: WU not reporting negative dew points with my Rainwise Mk III
Post by: ggsteve on December 30, 2014, 06:05:57 PM
The dew point has dropped below 0 for the first time I have noticed since installing my Rainwise Mk III.  My Weather Oracle, Rainwise.net and PWS are all reporting negative values for dew point.  Weather Underground has bottomed out at 0 and is flatlining right there.  WU is reporting negative dew point values for my Davis VP2.  Anyone else experienced this?
Title: Re: WU not reporting negative dew points with my Rainwise Mk III
Post by: ggsteve on January 07, 2015, 06:50:52 AM
Dew point is still bottoming out on WU at zero, but only with my Rainwise station.  The Davis VP2 and my daughter's Acurite are both reporting below zero readings over the past two days.  PWS clearly showed a drop to 3 below zero on it's data from my Rainwise.  I can't wait to see what happens tomorrow morning when actual temperature is supposed to be well below zero.
