Author Topic: Saratoga PHP/AJAX Website Template Set Update  (Read 577 times)
Offline SierraFoothills
    • Rail Road Flat Weather
« on: February 14, 2019, 09:30:27 PM »
I have been using Saratoga Website Template for a couple of years with Weather Display/Vantage VP2. What is the procedure for updating the template. Can I replace old PHP files with newer files? Comes to mind radar-status.php is much newer than the one I'm using and there are several more.
mike
http://weather.railroadflat.org
« Last Edit: February 14, 2019, 09:33:19 PM by SierraFoothills »
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
Re: Saratoga PHP/AJAX Website Template Set Update
« Reply #1 on: February 14, 2019, 10:07:20 PM »
You can run this file to see what needs to be updated and then download a zip file from saratoga-weather.org.
Run this on your site http://weather.railroadflat.org/check-fetch-times.php?show=versions
CW3699
Offline PaulMy
« Reply #2 on: February 14, 2019, 10:58:02 PM »
You can also use Ken's tool here to give you all the updates since a certain time https://saratoga-weather.org/wxtemplates/updates.php
It will have a Readme that gives instructions for each upload script.  Usually quite easy!
Enjoy,
« Reply #3 on: February 15, 2019, 06:22:55 PM »
Thanks both. Updated.
Mike
Offline Otis
  • (aka Paul)
« Reply #4 on: February 17, 2019, 01:51:55 PM »
Yep, you are welcome.
CW3699
