As a postscript:
I had to return my station to an unmodified GW-1000 as the longer antenna still had dropouts.
I finally found the problem. The higher gain antenna does increase the signal level but also increases interfering signals, that is, interference from routers, meteobridges and computers. When I moved the long-antenna GW-1000 to the opposite side of the room the dropout problem disappeared.
