That’s the thing - I can’t even successfully add the device in the Awnet app to see what firmware the console is running. Is there a way to update the firmware without a connection through one of the Ambient apps?
When I plug in the console it displays - 2 in the top left and then 1.06. Is that the firmware and I’m behind?
Like Mark said, and the WS-2902A Manual (v 1.5, 7.1.1,page 15) lays out, the AWNET Console Configuration app is required to connect with the internet.
"7.1.3.2 Android
Note: Make sure the awnet application has location services turned on by selecting APP PERMISSIONS from your android device."
Be sure to do this check as simply answering yes to a prompt during the installation doesn't always work. Related to this, I wonder if the Android version is relevant. What's the OS version you're running? Some users at the Google play store have posted issues on devices running version 9.
Also, be sure that the console and sensor array are close to each other; e.g., 5 to 10 feet.
Yes, upon first initialization of the console:
"6.2 Console Initialization
After the console is connected to AC power, the console will display the software version number two seconds after power up."
You might also consider starting from scratch, reset the console (6.11) and the sensor array - see page 54.
