Author Topic: other sensors for Vantage Vue, Pro 2 console, Weather Display?  (Read 1084 times)
Offline ANPweather
    • Anthem North Parkside, AZ
Just wondering if there other wireless sensors available that are compatible with my Davis equipment and/or with my wifi network and PC running Weather Display.
« Last Edit: August 11, 2018, 06:15:23 PM by ANPweather »
Davis Vantage Vue, Davis Pro 2 Console with Wifi Logger
Weather Display software
WU: KAZNEWRI17
PWS: ANTHEMNP
CWOP: EW7526
Offline SLOweather
    • Weatherelement Moline IL
Re: Have Davis Vantage Vue & Pro 2 console, are others sensors available!
« Reply #1 on: August 10, 2018, 06:06:28 PM »
Temperature only (sensor on a cable)
Temperature/Humidity (sensors in a radiation shield)
Leaf Wetness/Soil Moisture/Temperature (all sensors on cables)
Anemometer transmitter
I have at least one of each running at
http://www.weatherelement.com/teddybearoaks
Offline ANPweather
Re: other sensors for Vantage Vue, Pro 2 console, Weather Display?
« Reply #2 on: August 11, 2018, 06:32:25 PM »
With my standard size desert city lot I'm not looking for additional temp, rain, wind, moisture sensors. I guess I'm looking for something like solar, UV, air quality or ??? sensors.
I don't know if there is anything that would connect to and communicate through the Vantage Vue. I know the Pro 2 console can receive data from other devices but does that mean just additional sensor suites? The Davis solar and UV sensors I see seem to need to connect to the Pro 2 sensor suite.
So something that is one of:
- connects to and communicates through the Vue
- is/simulates a Davis unit and can broadcast direct to the Pro 2 console
- wirelessly connects to my PC running Weather Display
WU: KAZNEWRI17
PWS: ANTHEMNP
CWOP: EW7526
« Reply #3 on: August 11, 2018, 10:57:54 PM »
In a word, no.
Offline ANPweather
« Reply #4 on: August 12, 2018, 07:54:40 PM »
Kinda what I figured but had to ask. Thanks all.
WU: KAZNEWRI17
PWS: ANTHEMNP
CWOP: EW7526
Offline jas340
    • Lone Pine Ranch  Horseshoe Bend, Idaho  USA
« Reply #5 on: August 12, 2018, 08:34:11 PM »
The Vantage Vue console works with a VP2 running solar and UV sensors. I recently upgraded from a Vue to a VP2 ISS for around $300.00. Re-used the Vue console, added a Solar sensor and called it good.
