Your data looks good to me so far. Two thumbs up, 100% MADIS QC score and a green check mark are as good as gets.
I would watch things over time as you accumulate more data. Try not to become obsessed with chasing perfect
scores. If you do, you'll drive yourself insane!
Everyone, even Airport ASOS sites, will fail checks from time to time. Right now
the McCarran Airport ASOS has a big red X next to Dewpoint with a MADIS rating of 95%.
However, if you are
consistently failing MADIS QC (thumbs down) then you will want to look into the cause.
As far as your wind direction is concerned, you will want to ensure your wind sensor is aligned with True North not magnetic.
