Does that mean it is sensing the windspeed somehow, but not displaying it?
That seems unlikely. To be certain, (I couldn't tell from your posting of data, it had no column titles) are you seeing wind chill, or is the third column showing dew point? I really can't think of anyway that the console or weatherlink would calculate wind chill without a 10 minute average wind speed.
Where is it not displaying it?On my normally-operating VP2, if there is no wind, the anemometer is not rotating. There are no pulses from the anemometer reed switch. The ISS sends that information (no pulses). Therefore, the console displays the wind speed as zero. Software sees the same thing. After 10 minutes of no wind, the 10 minute average wind speed is zero.
The console calculates wind chill (and can display it). Calm = No Wind = Zero wind speed and is a completely valid weather condition. Therefore, the console calculates wind chill. The console doesn't care whether the anemometer is stuck, or broken, or not reporting, or whatever.
KDDA, what is happening differently from that (when your anemometer "isn't working")?
The formula for wind chill depends on temperature and wind speed, and is quite happy to work with zero as the wind speed. And in fact:
"any place where the result yields a wind chill temperature greater than the air
temperature, the wind chill is set equal to the air temperature. This always occurs at wind speeds of 0
mph or temperatures above 76F. This also occurs at lower wind speeds with temperatures between 0F
and 76F."
What am I missing here?
