Hello,
I have decided to revive my topic, because I found the reason why. The problem lies in weatherlink logger memory or is related with it. When the logger is full and should delete the oldest values by replacing with new ones, the station freezes. I have received this error two times already. My station is configured to 60 min. logging interval and after 65 days the station have frozen. So each time I take the data with a laptop, it is important to disconnect the station from power, than connect it again and restore power. I do not know, where the problem is (logger or console), but to my opinion there is no sense to try fixing it.
Adomas
As I recall, you're using "Weather Wizard complete station with weatherlink".
The "vintage" of your Weather Wizard, logger, and WeatherLink is about 1999. Firmware updates and WeatherLink updates aren't available. I'm not sure about the data size of your logger, but it's probably relatively small (perhaps 132 KB).
Out of curiosity, what's the version of the console firmware, and the version of WeatherLink that you are using?
If the logger is otherwise operating properly, then the console (firmware) is probably at fault - it should be handling the "full logger" situation.
You shouldn't have to disconnect power to reset things. After you download all the data to your laptop, use the Set Archive Interval command in the Setup menu to clear the memory.
I would suggest contacting Davis (via email), just to see if they have any suggestions - but you're probably on the right path to get a more recent station.
