Note: trouble with registration? See this for more info.
If you want more from software-Look at Weather Display.Then use VVP to run them at the same time.
In order to get what i want i need to use two software programs?
QuoteIn order to get what i want i need to use two software programs?Despite its appearance, Weatherlink's functionality serves a broad spectrum of users and is very solid. You can run one of the other weather programs instead of, or as chief-david mentioned, use more than one at a time by using Virtual VP (however this VVP is no longer supported and does not run for all setups).And it as agreed by most that Weatherlink looks dated and no function additions added for years compared to third-party programs that are regularly updated and have glitzy appearances.p.s. Cumulus weather program also logs extra sensors.Enjoy,Paul
Cumulus does show my two extra sensors but how do you view the high/lows for a day/month year etc it only seems to show that for the VP2 temps and only current data for the extra sensors.
Looking at the website tags i don't see extra sensor records tag. What am i missing?
<#ExtraTemp1>
Quote from: Adam HCumulus does show my two extra sensors but how do you view the high/lows for a day/month year etc it only seems to show that for the VP2 temps and only current data for the extra sensors.I haven't seen a way to view highs/lows but you can view the logs with both Cumulus and CumulusMX.Quote from: Adam HLooking at the website tags i don't see extra sensor records tag. What am i missing?I didn't search for the documentation, but I use Extra Temp 1. The web tag for it is:Code: [Select]<#ExtraTemp1>You could search for that and probably find the rest of them.
There seems to be no tag for high/lows of monthly/daily/yearly/alltime when it comes to extra temp sensors.
I bought a VP2 along with two extra temp/hum sensors i'm using weatherlink software that looks so outdated.I'm looking for a way to keep a record of the two extra sensors high and low data is there a way to do so? I have looked at the software part of the forum and see no software that logs this data and keep a record of it.
If you want run a Linux based system (i.e. RPI3+), Weewx has what you want. Quote from: Adam H on June 02, 2019, 06:58:59 AMI bought a VP2 along with two extra temp/hum sensors i'm using weatherlink software that looks so outdated.I'm looking for a way to keep a record of the two extra sensors high and low data is there a way to do so? I have looked at the software part of the forum and see no software that logs this data and keep a record of it.
Weatherlink may work but i need to see them remotely.
Bushman, i gave the Meteobridge route a try. I bought a TP Link mini router and the one i got Meteobridge would not work on! I got a V3 and Meteobridge needed a V2 or below so i never got to try it.But you say Meteobridge keeps the records for extra sensors? Weatherlink may work but i need to see them remotely.Thanks for your advice.
Quote from: Adam H on June 09, 2019, 11:26:27 AMBushman, i gave the Meteobridge route a try. I bought a TP Link mini router and the one i got Meteobridge would not work on! I got a V3 and Meteobridge needed a V2 or below so i never got to try it.But you say Meteobridge keeps the records for extra sensors? Weatherlink may work but i need to see them remotely.Thanks for your advice.https://www.meteobridge.com/wiki/index.php/Hardware Wich router did you get? And yes, it tracks all the extra sensors. https://www.meteobridge.com/wiki/index.php/Live_Data shows some extra sensors; I've used the ISS and two extras. As well MB allows you to log in via a magic URL and see it from anywhere in the world.
Quote from: Adam H on June 09, 2019, 11:26:27 AMWeatherlink may work but i need to see them remotely.Is that the first time you've mentioned remotely?Hmm, I have something that would do this for you but you'd need to upload to weatherlink.com (eg from Weatherlink for Windows) and it's not a solution that's on general release.
And I'm guessing that something special needs a pro subscription?
