Author Topic: Building my own solar radiation shield for temperature & humidity sensor  (Read 3150 times)
Offline AdkManUpstateNY
Hi. I am planning to build my own solar radiation shield for the digital temperature and humidity sensor unit to my La Crosse Technology S84060 Professional Weather Station. I'm waiting for the arrival of some white Melamine plastic rounded square salad bowls I purchased online. They are 9" in diameter and 3.5" tall. I ordered four of them. I plan to leave a generous 3" gap for air flow and ventilation between each bowl. 1/2" of their 3.5" height will be the overlap distance between the bottom and the top of the stacked bowls. I have found a few places on the internet where some folks have described "somewhat" how they constructed theirs.
My question: Should the very bottom of the solar radiation shield be left open for better upwards air flow and ventilation? Or closed by leaving the bottom bowl with no drilled hole in the center? *I intend on installing a fine, plastic mesh insect screen completely around the interior to keep the bugs/bees/insects out. The digital sensor (LTV-TH3 Sensor) measures 5.73" tall...1.97" wide...and 0.75" deep (or thick) at its deepest point.
Here's a crude graphic I drew up using Microsoft Paint. **Not to scale. Melamine salad bowls are not rounded on the corners.
The temperature/humidity sensor unit.
The Melamine bowl (x4)
« Last Edit: June 05, 2019, 01:52:09 AM by AdkManUpstateNY »
La Crosse Technology S84060 *Currently on WU*
AcuRite 00386SDI
Offline havtrail
    • Haverford Weather Station
Others will weigh in with varying opinions. I have a higher-end Onset HOBO weather station, with their passive RS1 Solar Radiation Shield. From what I've read and seen, shields are generally only open on the bottom if they are fan-aspirated. Many people on this forum favor fan-aspirated shields that have open-bottoms, but some have expressed worries about rising heat coming in that bottom opening from whatever surface is below.
The Onset RS1 is a large, solid unit that is sold separately for $79. Like many better shields, it has both fully closed and open-center plates, and a metal plate at or near the top to handle the most direct rays of the sun. Mine is now 10 years old and still looks brand new; some plastics will deteriorate badly in the sun and weather. I mention it only for comparison purposes. It's worth looking at their page for the RS1 at https://www.onsetcomp.com/products/mounting/rs1
Under the "documentation tab, you can read their installation guide, which contains thorough descriptions of parts and many drawings that may give you some ideas. Make sure you can easily disassemble your shield to keep it cleaned out inside.
Rich K.
Onset HOBO RX2102 Cellular
Hard to beat these. Rated as one of the best naturally aspirated shields by WMO in field test conducted a few years back. Scaled instruments sells them cheaper than retail around $67.
I made a shield from 5 plastic bowls from the dollar store.  Cost me five bucks all in.  I used threaded rod and leftover plastic tube for the spacers.
Exactly why proper sitting is crucial to any wx station, PWS or otherwise. A closed vs open bottom will suck (pun intended) equally as bad sitting over asphalt.
Thanks to those for their input  [tup]
But I still don't know which is preferred  :???: I don't plan on it being fan aspirated. If not, which is better... an open or closed bottom?
AcuRite 00386SDI
Experiment. They are just salad bowls, right? Put holes in one and not the other.
Yes, they are salad bowls. But they are not cheap, flimsy plastic ones. And I only ordered four of them on account of their size: 9" x 9" (rounded square bowls) that are 3.5" tall. I'm thinking the finished radiation shield will be 12" tall. The temperature/humidity sensor it will house is just 5.73" tall. Of course the top bowl will be solid and without a hole (lol). The next two will have holes cut out in their center to accommodate the sensor. It is the bottom bowl I am unsure of. Keep it solid or cut a hole in the center to create an open bottom? They are made of Melamine plastic. Melamine is rated to have a very good UV resistance. And medium to excellent heat resistance. It is very durable and very hard plastic.
« Last Edit: June 07, 2019, 05:20:42 PM by AdkManUpstateNY »
AcuRite 00386SDI
In my HM shield. I used a hole saw to drill about 4" holes in all but the top bowl.  Gotta find that picture...
I won't know the diameter of the holes in mine until the bowls arrive in the mail and I get to see what I'll have to work with. I look forward to seeing it if you can find it Bushman  :-) [tup]
« Last Edit: June 12, 2019, 12:46:00 AM by AdkManUpstateNY »
AcuRite 00386SDI
The bowls finally arrived in today's mail. These were advertised as being 9" rounded square bowls, but measure 8 7/8" in diameter. They were also advertised as being 3 1/2" in height, but only measure 3" in height. I got a great start on its construction late this evening. The only things left to do are cutting out "squares" in either two or the final three bowls to accommodate the digital temperature and humidity sensor unit. And I still need to finish up the mounting bracket(s) on the top...and cutting a few more "spacers" needed. Here's some pics. of the rough dry fit. I added in the water bottle for size reference. It should top out at around 12" tall with the mounting bracket hardware included on the top  :grin: As you can see, I went with four threaded rods 1/4" in diameter and 12" long rather than the usual three threaded rods as most seem to use when fabricating these. I think four rods in a square configuration is more study and stable than three rods in a triangular configuration. I hope to finish it within the next day or two. I will post more pics along the way when I can.
« Last Edit: June 12, 2019, 12:39:59 AM by AdkManUpstateNY »
AcuRite 00386SDI
Offline PacoJavi
I personally would reduce the length of the spacers. In theory you should not see the sensor inside the housing from any angle (although you have not installed it yet). In this way you avoid the reflected radiation, or so it is my understanding.
Those bowls look class though. Can I ask how much they were?
Offline havtrail
As I think I suggested earlier, if it will not be fan aspirated, I would leave the bottom bowl solid with no hole cut into it. That's the way my Onset HOBO "factory" one is. Hope it has been a fun project for you...
Rich K.
These bowls have a very glossy/high shine finish. I believe they will do a fine job at reflecting the Sun's rays rather than absorbing them. These bowls were listed at $8.99 each marked down to $3.00 a piece at a website called Hollar.com
AcuRite 00386SDI
Rich K.
It was a fun project until it came time to cut the square openings in these Melamine hard plastic bowls. I decided to only leave the top bowl untouched. I drilled a series of holes to make room for my sabre saw blade, and cutting out these square holes was a chore...at times the plastic shattered  :roll:
To suspend the temperature and humidity sensor unit inside, I simply used plastic coated "twist-tie wires" you get on loaves of bread. I am NOT happy with the strength of the two white shelf brackets I purchased from a hardware store. They bend too easily. I plan on coming up with a more sturdy mounting bracket in time. This solar radiation shield is very sturdy and built strong!!
« Last Edit: June 13, 2019, 11:14:08 AM by AdkManUpstateNY »
AcuRite 00386SDI
More pics.
AcuRite 00386SDI
Since I only rent the upstairs apartment in this building, and the lawn space being quite narrow, I am limited in where I can site this solar radiation shield. I don't dare attempt to sink a wooden post in the middle of the lawn. My older AcuRite 00589 outdoor sensor was mounted using a satellite dish mounting arm close to three years ago. I had no other choice but to mount it to a tree. That sensor has performed remarkably well given its close proximity to the road and for being underneath a tree. So I will soon see how this solar radiation shield for the temperature and humidity sensor to my La Crosse weather station performs mounted here. It sits 7' above the lawn. The AcuRite 00589 pictured sits at 8'.
AcuRite 00386SDI
AcuRite 00386SDI
Offline DoctorKnow
Under a tree is not the best place, but it isn't a really large tree, and it is a good distance from any buildings. The roadway will likely affect things, especially if a light breeze is off of it in it's direction.
I really don't understand why everyone says under a tree is not a good place. In the late spring, during the summer, and up until the foliage falls off trees in the autumn, they provide protection from the sun's rays and provide a much needed shaded area. And mine is far from any building..probably a good 200' + away from my apartment building. It's also not up close against the tree, and I really don't see where humidity would be any worse where I have it as compared to over the open lawn.
AcuRite 00386SDI
Q@M o
« Reply #20 on: June 14, 2019, 10:26:19 PM »
I'm not agreeing or disagreeing with this article as I have absolutely no way of attempting it, but know a quality shield is designed for complete, unabated sun exposure.
https://weatherstationexpert.com/things-to-keep-in-mind-when-installing-a-weather-station/
Re: Q@M o
« Reply #21 on: June 14, 2019, 10:36:55 PM »
Your link above makes sense as it states: "Never install your weather station under a tree or overhang, as this can make the rainfall data measured by your system incorrect."
This radiation shield I built is for the temperature and humidity sensor only. The rain collector in located 29' off the ground and is mounted above and off to the side of the roof and nothing around it for 100-150' or more. And I did not purposely site it beneath the tree because I don't have confidence in its ability to perform adequately in full sun exposure. The other day I left it outside in the blazing sun to see how much the melamine bowls heated up to direct exposure to the sun's rays and it was remarkably quite cool to the touch when I removed it from the sunlight. I mounted it where I did because space is limited and I have no better options. My AcuRite 00386SDI weather station multi sensor has been mounted there for over 2.5 yrs. now and has performed flawlessly.
« Last Edit: June 14, 2019, 10:40:47 PM by AdkManUpstateNY »
AcuRite 00386SDI
Re: Q@M o
« Reply #22 on: June 14, 2019, 11:06:36 PM »
I didn't post this link about rainfall, that's hopefully the obvious part. We're taking about radiation shields, right? If you'd read down further, this was stated:
Humidity sensors must be located at least 50 ft away from any plant, tree or water body, as they can affect the humidity measurements. Even if there is any of it, the humidity sensor must be at least 50 ft away from it.
Like I said, no experience myself, but makes sense, especially after a rain.
Re: Q@M o
« Reply #23 on: June 14, 2019, 11:17:06 PM »
I read the entire article. And as I stated I do not own the land on which I live. I rent the upstairs apartment. The lawn is not all that big. It's much longer than it is wide. The lawn is bordered by a creek on one side. Just below the brush and bushes you see in this pic. and to the left. And it's bordered by a paved street on the other side. I do not dare dig up the lawn which again is not mine and sink a wooden post smack dab in its narrow center. I don't mow the lawn and I don't think the caretaker who does wants to mow around a wood post. I sited it as best as I could and what I have to work with. And the article makes a pretty silly statement by saying 50' away from any plant(what a joke!) tree, or body of water. Mounting a solar radiation shield at least 5 feet above grass violates the 50' rule in my honest opinion. Grass is a plant/vegetation!!! It holds moisture too!
« Last Edit: June 14, 2019, 11:20:45 PM by AdkManUpstateNY »
AcuRite 00386SDI
You wondered about why trees and sensors potentially do not belong together, I supplied the article, be it right, wrong, or indifferent. There are very few PWS owners who "have it all". Considering your situation, you're lucky to have what you have.
