I am going to mount my weather station on a 2nd story wood deck. I was going to use the railings as far away from the house as possible to prevent any anomalies with wind and/or rain readings. The instructions indicate the wind vane and main ISS station should be on opposite sides of the post. Unfortunately, that will not be possible for this set up.
I may be looking at it too literally but does it really matter if the vane and ISS are not on opposite sides of 1 post? I would try to mount the rain gauge above the railing to prevent as much splashing as possible.
Here are the 2 places I was looking to mount. Again, this is a temp set-up as I will be moving by the end of the year. Both locations are below the roof line if you couldnt tell. The 1st photo shows the railings approx. 10-15 feet away from the house. The 2nd photo shows the stair railing which is lower and somewhat between the 2 houses (approx. 7-9 feet from the back of the house). What do you recommend is a better spot? The install would likely look like the instruction manual's example on page 20 (flat surface install). If someone can tell me how to add images or point me in the right direction, I have suggested locations that I am looking for advice with.
