Another reason I decided to use Weather Display instead of MBW. I had problems during the setup process, so I suspected there would be other problems later down the road.
I thought that WD as a product died in a horrible hard drive crash that wiped the source code? Upon checking the WD web site, it appears that the developer spent almost a year re-creating the program...and just released the first revision since last winter.
You guys that are using the MeteoBridge, do you have to use MBW? Or can you use some of the other available weather station software?
There are two ways that MeteoBridge gets Acu-Rite data. If you have a USB console, you can connect it to MB (via a USB hub on some router hardware) and it will upload your data to any of the supported online services. If you have the Acu-Rite network bridge, you can plug its network cable into the network port on the MB router. MB will "sniff" the packets being sent to MBW, and then pass them through via wifi to your home router. It will also pass along that sniffed data to any of the supported online services in real time. In other words, it updates Weather Underground at least once per minute instead of the MBW 15-minute update logic.
The pitfall to using the network bridge is that MB needs to see the packets flowing to MBW to sniff them. If packets aren't flowing to MBW for some reason (like a DNS failure), then MB has nothing to sniff. I suspect that this was the probable cause of the data gaps everyone saw the other night.
MB does not store data for archival purposes, but it will do raw uploads to a SQL or web server and even fill in the popular weather web templates if you have your own site.
The biggest reason for me to use MB is that I don't have to leave a Windows PC running 24/7 to read my USB console data and export it to various online services. MB runs standalone flashed in a $20 travel router (D-Link DIR-505 recommended for Acu-Rite network bridge sniffing due to extra RAM), and is truly plug and forget. The router itself is the size of a small wall wart transformer, and plugs directly into an outlet (ie: zero desktop/rack/shelf footprint). Mine hasn't been rebooted since I installed it 122 days ago. Since I already had the network bridge, I chose to use that and the packet sniffer code for my MB input. I also have a USB console, and could have used that if I spent a few more bucks for a USB hub to convert between USB versions. If MBW continues to have hiccups, I may change over to USB.
One thing to note is that I don't know if MB supports the latest batch of Acu-Rite USB consoles (the xxx6 models). My 1035 worked fine with MeteoHUB on a Raspberry Pi, and I have no reason to believe that it wouldn't work on MB.....
