Author Topic: Bloomsky's Not Reporting?  (Read 2037 times)
Offline CNYWeather
    • CNYWeather
« on: May 10, 2016, 07:42:13 AM »
I see the script returns the following error:
Data retrieved: (
Also got a notice from WU my Bloomsky is not reporting.
Tony
Offline Maumelle Weather
    • Maumelle Weather
Re: Bloomsky's Not Reporting?
« Reply #1 on: May 10, 2016, 07:52:50 AM »
Same here, Tony. Nor does the app work. The map works. It looks like the API flipped out. All of my Favorites are gone, including my own camera. I'll have to redo it when I get home.
GR2AE, GR3, Cumulus
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #2 on: May 10, 2016, 08:01:48 AM »
Again? I don´t want to be picky, but is there a day without someone reporting problems regarding BS?
Offline kc2kzz
    • Solitude Village Weather
« Reply #3 on: May 10, 2016, 08:11:44 AM »
I think this is a larger than normal issue.  Nothing is working on my end either.  I couldn't get into the data portal yesterday (gave some sort of application error message).  Today you get the login page but just hangs after that.
« Reply #4 on: May 10, 2016, 09:04:49 AM »
Also currently can't access the portal and got the WU message of not updating, but both my home device and my daughter's Milton device are current on the map, which for many is the main purpose of their BloomSky!.
Offline kc2kzz
« Reply #5 on: May 10, 2016, 09:54:49 AM »
I just checked and everything appears to be working again for me.
Offline nincehelser
« Reply #6 on: May 10, 2016, 10:03:57 AM »
The Wunderground stuff is broken, but the Bloomsky app and map page seem to be working fine for me.
Offline CNYWeather
    • CNYWeather
« Reply #7 on: May 10, 2016, 10:46:20 AM »
WU emailed it's back up again. Script working also.
Tony
Offline SpringHillWeather
  • Weather Hobbyist
  • Spring Hill, Florida
    • Spring Hill
« Reply #8 on: May 10, 2016, 02:46:04 PM »
Thanks for the post.  I also received the WU email this morning saying I've been offline, so your post confirmed quickly I needed not to worry and check my Bloomsky or router.
Maybe they had a server issue but least we were back up relativity quick.
As mentioned growing pains....  If you look at the map you'll see numerous BS popping up all over the place.
Also with the new APP update which is sending forecasts, more frequent notifications and other features its probably starting to overwhelm their systems.
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Offline CNYWeather
    • CNYWeather
« Reply #9 on: May 10, 2016, 03:33:34 PM »
Down once again on WU per their email.
Tony
Offline kc2kzz
« Reply #10 on: May 10, 2016, 03:53:43 PM »
I got the notification also.
This is what I don't like about having to rely on a 3rd party's server.  If we had direct access to the device, we could at least still get some functionality out of it.
Offline nincehelser
« Reply #11 on: May 10, 2016, 04:08:52 PM »
Huh?  The link between Bloomsky and Wunderground is the problem here.
I can access my Bloomsky just fine.
As for direct access to the device, that might be possible, but the way they shut down the wifi to save power makes it a challenge.
Has anyone captured the traffic to see if it is encrypted or not?
Offline nincehelser
« Reply #12 on: May 10, 2016, 04:33:03 PM »
Oops.  Disregard.  I guess you might be talking about using the data portal.
Offline kc2kzz
« Reply #13 on: May 11, 2016, 06:08:20 AM »
I mean just in general.  If bloomsky suffers a prolonged outage, these are useless.  It would be nice to be able to pull data out of it on our own somehow.
Offline nincehelser
« Reply #14 on: May 11, 2016, 12:03:47 PM »
Well, as I said before, this outage isn't affecting the Bloomskys themselves.
Someone will have to dig in and do some more research to determine if the communications can be monitored locally.  If we're lucky, hopefully it isn't overly encrypted or obfuscated.
