I used a TV antenna mount designed for a gable end. It stands everything off the pole several inches and is configured to hold a 1 1/4 pipe for the equipment to mount on with "U" bolts. I had to re-form (bend) the ends a bit to wrap around the pole. Also adjusted things so I could slide the 20' mast up and down in the mount's clamps for easier positioning.
