Author Topic: Serial to USB Adapter Advice Needed  (Read 3242 times)
Offline wxtech
    • Lexington, Ga. Weather
« on: November 15, 2009, 08:38:51 AM »
There have been discussions of serial to USB adapters that worked and some that don't work with the Davis system.  I need some recommendations of which one I should order.
I have a Davis VP2+ with WeatherLink data logger that was purchased in 2004 (don't know the software version).  I can download the latest software from Davis.
The computer that I'll use is a Compaq Presario CQ60 dual CPU t3400 @ 2.17GHz running 32 bit Vista Home Premium.
My old computer power supply has finally died.  I'll install a new power supply and try to revive it but I still want the laptop to connect to the wx station.
Al
Re: Serial to USB Adapter Advice Needed
« Reply #1 on: November 15, 2009, 09:07:17 AM »
The ones with a Prolific brand chipset work best it seems.  I know softwx.com sells one.
Offline d_l
  • Slide Mtn - Mt Rose
« Reply #2 on: November 15, 2009, 09:45:30 AM »
The Tripplite Keyspan USA-19HS works well with the Davis serial logger.  It uses a TI USB chipset and a Zywyn RS232 transceiver.
--Dave--
blackjack52
  • Guest
« Reply #3 on: November 15, 2009, 09:46:59 PM »
So does the Cablemax w/ FTDI built-in chip; no drivers required.
Offline NDSWeather
  • NDS Weather - Colorado City
  • NDS Weather - Colorado City CO
« Reply #4 on: November 16, 2009, 09:58:24 AM »
Prolific is that way to go from USB to Serial, I have not found Serial to USB adapter anywhere on line.
They work well with astro equipment as well.
Remember to turn OFF power management for the USB port.
For Laptops PCMCIA Cardbus is a better way to go.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3981717&CatId=1422
http://www.newegg.com/Product/Product.aspx?Item=N82E16839328020&cm_re=pcmcia_to_serial_adapter-_-39-328-020-_-Product
Good Deals here as well
http://www.serialgear.com/1-Port-Serial-PCMCIA.html
Single Port Slim
http://usbgear.com/computer_cable_details.cfm?sku=RS232-PCMCIA1&cats=464&catid=585%2C538%2C464
http://www.buy.com/prod/rs232-serial-db9-cardbus-pcmcia-cable-adapter-for-gps/q/loc/101/208927812.html
http://www.cdw.com/shop/products/default.aspx?EDC=1428315
NDS Weather
« Last Edit: November 16, 2009, 10:21:36 AM by bcavnaugh »
6153 Davis Wireless Vantage Pro2 FW 1.90 Serial Port
Now Only WeatherLink 6.0.5
KCOCOLOR2154 CW4784
