Author Topic: NWS website changed .. advforecast2.php V3.03 02-Jul-2012 now available  (Read 24484 times)
Offline Gordon
Nice work Ken...but I lost my drop down city forecast selector:
http://www.oldlineweather.com/wxforecast.php
Even with a fresh copy of the update with no modifications it's still a no-show.
Any insight is appreciated!
Gordon
<iframe src='https://www.weatherlink.com/embeddablePage/show/3512bdb6075043fba2e0fbf66996d8f0/signature' width='760' height='200' frameborder='0'></iframe>
Offline azkiwi
    • Maricopa, Sonoran Desert, Arizona
Hi all,
user pointed out to me forecast wasn't working, so I did some digging and found this thread and the new advforecast2.php file.   Had some issues in getting it, when i clicked the download, it did a text display, so i saved the page.  Had to use wordpad to format the layout.  Then found addition info had been inserted in line 1, so i removed it and loaded it to my test bed.
I get this response - and have no idea even where to begin looking...
<br />
<b>Parse error</b>:  syntax error, unexpected ';' in <b>/virtual/users/e14384-17518/web/advforecast2.php</b> on line <b>122</b><br />
my test bed is way out of date data-wise, but it's here
test.azkiwis.net
will someone please take a look and tell me where to go to fix it?
I was previously using v3.00  of 12 Mar 2011
Ken
Offline SoMDWx
    • Southern Maryland Weather
Hello From So. MD!
  There is an array in the code near the top which you can uncomment that allows for a dropdown list of the towns/cities you'd like to have a forecast for. There is a set of cities already there that Ken has pre-populated from CA. You just need to eliminate the lines you don't need and inerst the data for the cities of interest.
Jim
Hi Gordon,
Your advforecast2.php has
$NWSforecasts = array(
.. just change it to
and your selector should be enabled again.
I'd put the selector inside /* */ comments so folks wouldn't use my default selectors if they had not customized the script itself.
Best regards,
Ken
Hi all,
<br />
test.azkiwis.net
Ken
Hi Ken,
With a parse error, it's not possible to see the source remotely (since the parse error precludes execution of the entire script).
Since you'd had issues doing the download using the ?sce=view option, I'd suggest you try the updates tool which will create a .zip file with the source included in the file.  Just save and extract advforecast2.php from there as a good starting point.
Best regards,
Ken
Offline azkiwi
Ah. moment of enlightenment.
I think the way I got the code was dangerous, bad at least.   Digging thru Ken's site, I found the .zip with everything in it, so d/l'd, unpacked, loaded, tested, and it worked, right out of the box.
As usual it seems to be me -- knowing where I want to go, what I want to do, but lacking the code skills to really understand.
Thanks Ken for your update!
(another) Ken
<br />
test.azkiwis.net
Ken
For the adventurous, I've posted at pre-release V3.04 with two fixes:
1) the infamous validation errata (unclosed <img tags) from the NWS
2) shortening 'Thunderstorm' to 'T-Storm' so the icons won't overflow.
Test version at http://saratoga-weather.org/advforecast2-test.php?sce=view
Let me know how that works out and I'll finish the packaging for release :)
Thanks folks for spotting the stuff needing additional fixing .. I was rushing like crazy to get the parsing working and neglected to check the XHTML 1.0-Strict validation before release.. the -test version above does validate clean :)
Best regards,
Ken
Offline capeweather
    • http://www.capeweather.com
Thanks again Ken! You rock!
Chris
Cape Coral, Florida
Offline dasman
    • Wx Peotone
Ken the new version Validates and the T-storm is correct as well.  Thanks Again!
Dave Sommerfed
Peotone Illinois USA
CW7762, KILPEOT1
Offline K4KMG
    • K4KMG.com
Working great here.
Thanks Ken
K4KMGWeather.com
Living 'Off Grid" in Central Florida. Pics at k4kmg.com
Offline gwwilk
  • Southeast Lincoln Weather
Works right out of the box, and validates!  Thanks, Ken =D&gt;
Regards, Jerry Wilkins
gwwilk@gmail.com
Thanks folks :)
I've released 3.04 version .. let me know if any errors pop up with this one :)
Best regards,
Ken
Offline Gordon
Hi Gordon,
Best regards,
Ken
Well that was easy! Thanks Ken...and thanks for your reply as well Jim...
Gordon
Online chief-david
Version 3 working here too.
thanks Master Ken
Offline AWL
    • Ardmore Weather Live
V3.04 working here. Thanks again for all your hard work.
Doug
Offline Andy G
    • SunPrairieWeather.com
3.04 working here just wish it was forecasting a little cooler temps.
Thanks Ken
~Einstein
Davis VP2 24 FARS
Offline cospringswx
    • Colorado Springs Weather
Working here as well. Thanks again Ken for  everything you do!!!
http://hayskansasweather.com/wxforecast.php
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Offline SoMDWx
Ken,
  If I wasn't married...    :shock:   Who said that?
Seriously, we can't say enough to thank you for all that you have done to keep everything going.... The script works like a champ!
Regards,
Jim
« Last Edit: July 03, 2012, 12:42:54 PM by SoMDWx »
Offline cospringswx
Only thing thats wrong with mine is the high temps and no rain :roll:
Ryan
Davis Vantage Vue
Offline ke9lz
  • De Pere - Athelstane Weather
    • De Pere Weather
Hi Ken,  I was able to update one of my sites with the new version without a hitch but having problems with this site http://weather.athelstanewi.com/ .  I get this error message (Warning: strpos() [function.strpos]: Offset not contained in string in /home/content/s/t/e/stevemcd/html/weather/advforecast2.php on line 474).  I have not updated this site to your new ver 3 as of yet but since it was modded with an alternative dashboard and using VWS, I chose to leave it alone since it was working very well (kind of like if it isn't broke, don't fix it).  Anyway, do I need to update the site to ver 3 to use this script?  Turning out to be a bad week as the computer that updates the site also took a dump ](*,)
Steve
« Last Edit: July 03, 2012, 01:18:46 PM by ke9lz »
Steve (KE9LZ)
Athelstane Weather
Blitzortung 1177, 1565
Offline K4KMG
    • K4KMG.com
Steve, not sure if it's what your looking for but Ken posted links to Ver3 AND Ver2 script updates in the first post of this thread.
Tom
Offline ke9lz
    • De Pere Weather
Hi Tom, Yes, I am using the ver 2 script pulled from Ken's site.  Guess it is something I am doing wrong within the site.
Thanks, Steve
Steve (KE9LZ)
Athelstane Weather
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
Hi Steve,
You might want to edit in the Settings area in the advforecast2.php to reflect your NOAA area site.  I did that and it seems to work for me using ajax V2 but I am in the process of updating to V3.
Hope it works out for you.
--Stan Y.
  Maui, Hawaii
 --- Blitzortung ID: 993
 --- FlightRadar24 ID: F-PHOG1
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
Webcam: Axis 211
Offline cospringswx
This worked for me
Ryan,
In your Settings.php you have
Code:
$SITE['NWSforecasts']   = array( // for the advforecast2.php V3.xx version script
// use "Zone|Location|Point-printableURL",  as entries .. first one will be the default forecast.
  "CAZ513|Saratoga|http://forecast.weather.gov/MapClick.php?CityName=Saratoga&state=CA&site=MTR&textField1=37.2639&textField2=-122.022&e=1&TextType=2",
"CAZ513|Los Gatos|http://forecast.weather.gov/MapClick.php?CityName=Los+Gatos&state=CA&site=MTR&textField1=37.2267&textField2=-121.974&e=0&TextType=2",
"CAZ513|Cupertino|http://forecast.weather.gov/MapClick.php?CityName=Cupertino&state=CA&site=MTR&textField1=37.3231&textField2=-122.031&e=0&TextType=2",
"CAZ513|Sunnyvale|http://forecast.weather.gov/MapClick.php?CityName=Sunnyvale&state=CA&site=MTR&textField1=37.3689&textField2=-122.035&e=0&TextType=2",
"CAZ513|Santa Clara|http://forecast.weather.gov/MapClick.php?CityName=Santa+Clara&state=CA&site=MTR&textField1=37.3542&textField2=-121.954&e=0&TextType=2",
"CAZ513|San Jose|http://forecast.weather.gov/MapClick.php?CityName=San+Jose&state=CA&site=MTR&textField1=37.3394&textField2=-121.894&e=0&TextType=2",
"CAZ508|Mountain View|http://forecast.weather.gov/MapClick.php?CityName=Mountain+View&state=CA&site=MTR&textField1=37.3861&textField2=-122.083&TextType=2",
"CAZ529|Santa Cruz|http://forecast.weather.gov/MapClick.php?CityName=Santa+Cruz&state=CA&site=MTR&textField1=36.9742&textField2=-122.03&e=0&TextType=2",
"CAZ006|San Francisco|http://forecast.weather.gov/MapClick.php?CityName=San+Francisco&state=CA&site=MTR&textField1=37.775&textField2=-122.418&e=0&TextType=2",
  You can change that to
Code:
 then the ONE forecast you have configured for Hayes, KS will appear instead.
Also, the Settings.php file is the one used.. there is no settings.php (with a lower-case S) used by the templates.
Linux/*nix servers pay attention to upper/lower case letters in file names .. Windows systems do not.
Ryan
Davis Vantage Vue
Steve
Hi Steve,
I ran http://weather.athelstanewi.com/wxforecast.php?force=1&debug=y and did a view-source on the page which shows
<!-- advforecast2.php (multi) - V3.04 - 03-Jul-2012 -->
<!-- NWS URL: /http://forecast.weather.gov/MapClick.php?CityName=Athelstane&state=WI&site=GRB&textField1=45.43&textField2=-88.09&e=0&TextType=2 -->
<!-- zone=WIZ013 -->
<!-- Network error: php_network_getaddresses: getaddrinfo failed: Name or service not known (0) --><!-- loading ./cache/forecast-WIZ013-0.txt -->
The issue is the bad URL (with a leading /) .. delete the leading slash and the URL should work for you.
Best regards,
Ken
