Author Topic: Webcam and IP cam  (Read 1581 times)
Offline stonefox
Webcam and IP cam
« on: June 22, 2016, 03:00:37 PM »
There is a Webcam setup in WD, but is there a IP Cam setup ?
Or a solution to setup IP Cam ...
Offline Aardvark
    • turned off
Re: Webcam and IP cam
« Reply #1 on: June 22, 2016, 03:14:36 PM »
it is the same.
here is what i put in to get my ipcam to behave.   you have to put in your own camera ip address, port and user name and password. Should work fine.
http://192.168.0.11:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=SnowCam&pwd=1947
Offline hankster
    • NFM Weather
« Reply #2 on: June 22, 2016, 03:43:13 PM »
Look in Windows Task Bar, might have to click the little up arrow on the lower right side of the screen. There you should see an icon with a camera on it. Click on it to open the Web Capture program. You will then find the tab at the top of that page for the IP Camera Setup.
Best bet would be to ask on the Weather Display forum as there are many more WD uses there.
