Which subscription? Also, A Meteobridge connected to a Davis Vantage by an Davis data logger (regardless if serial, USB or IP) exposes the Vantage on port 22222 like a Davis IP data logger. This allows other weather programs to also connect to the Davis Vantage and to read data in parallel from it. Only one additional program can read data from the Vantage. Function is a bit similar to the "Virtual Vantage" program that has been offered as a PC solution. Difference is that Meteobridge also supports LOOP2 communication (which "Virtual Vantage" does not) but as a downside Meteobridge can handle only one additional client (instead of 8 like "Virtual Vantage")
