Author Topic: CWOP quality control  (Read 2616 times)
Offline flyingvranch
    • KI5OMM Weather Station
« on: November 20, 2015, 12:29:03 PM »
Since I am new to reporting for CWOP, I am a bit confused as to where do the quality control graphs come from? When you look at my page http://weather.gladstonefamily.net/site/E8194, you see the graphs of my temp and barometer compared to their analysis of what they think it should be. How is this calculated? My barometer was off slightly and I have adjusted that. But my temp is lower than the analysis and that is a problem. I have compared my Davis temp probe to my certified lab-grade mercury thermometer and it is spot on at all ranges. The local METAR is about 8 miles away and is right next to a busy freeway and much asphalt and concrete and is always a few degrees higher than mine which is located inside a Stevenson screen located exactly 5 feet off the ground over short mowed grass in a rural area. Any tips or ideas so I can better understand what is happening?
Thanks!
Re: CWOP quality control
« Reply #1 on: November 20, 2015, 01:37:07 PM »
Offline W3DRM
    • Emmett Weather
« Reply #2 on: November 20, 2015, 02:13:26 PM »
You will find lots of discussion on this subject throughout this forum. It is a known fact that many so-called "official" weather stations are poorly sited. You'll even find photos taken of these weather instruments located in parking lots with asphalt, buildings and other objects in close proximity to the sensors. Unfortunately, all of this poor siting results in bad data being captured.
You'll also find that in many locations, the barometric readings always show out of tolerance according to MADIS. Mine is an example of that situation. While all of the surrounding barometric readings in my area are stable and follow my reading, the "analysis" readings look like a wild roller-coaster ride. It is very obvious there is no way barometric readings could change so drastically or in such a short period of time. I and many others have simply given-up trying to fight the system on this...  ](*,)
--- RIPE Atlas Probe - 32849
Offline virusdunil
    • Station Meteo Hebertville
« Reply #3 on: December 02, 2015, 11:26:34 AM »
Is cwop really accurate/relyable ? http://weather.gladstonefamily.net/site/E6411
last week my baro readings were at 95% rating
today its at 79 % withSensor fails following checks:
L3 Spatial Consistency
the thing is i didnt touch anything/played in the stations settings :roll:
Cabled Vantage pro2 + Solar / Stevensen screen
Weather Display latest version + Boltek PCI-NexStorm-StormVue NGX / NSDisplay
http://www.meteolacstjean.com/weather28/index.php
Meteotemplate : http://www.meteolacstjean.com/hebert/index.php
« Reply #4 on: December 02, 2015, 01:43:21 PM »
The only thing you've done wrong is concerning yourself.
Offline virusdunil
« Reply #5 on: December 02, 2015, 01:53:31 PM »
not sure to understand that :roll:
« Reply #6 on: December 02, 2015, 01:58:17 PM »
If you know your data is good, and you seem too, then quit going to that site. All you'll do is give yourself an ulcer, because it damn sure ain't gospel. ;)
Offline virusdunil
« Reply #7 on: December 02, 2015, 02:07:25 PM »
 =D>
saying it this way...i now understand  \:D/
Offline Scalphunter
« Reply #8 on: December 02, 2015, 02:19:02 PM »
also it winter so barometer  follows the heat in your house.  It not much  but still affected by it.
Offline ValentineWeather
« Reply #9 on: December 02, 2015, 03:24:47 PM »
If its a bad barometer giving erroneous pressure readings you may be able to contact Madis. Problem is identifying the culprit.  Look at this thread http://www.wxforum.net/index.php?topic=25614.0
Randy
Offline zackdog
    • Winter Park Highlands Web cams
« Reply #10 on: December 06, 2015, 09:40:54 AM »
Went to quality control today for the first time in months, now I know why.   ](*,)
"You don't need a weatherman to know which way the wind blows." - Dylan
Vantage Pro2 Plus w/ 24 hr FARS and (2) VantageVues
VP2 uploading via Vue console to CWOP, WU, PWS, and Weathercloud.
