Author Topic: UPDATED: Script to Display US and Territories Radar Using HAniS  (Read 31461 times)
Offline mldenison
    • York, PA Weather
Re: UPDATED: Script to Display US and Territories Radar Using HAniS
« Reply #150 on: November 06, 2017, 07:05:09 PM »
I stumbled upon this thread and I really like the radar display.
Unfortunately, I'm a bit below mediocre when it comes to implementation.
I've got the files copied to my website.
I don't know how to integrate it into Saratoga.
I'm OK with creating a flyout item for it.
I just don't know the code snippet(s) required to fire it off.
Can anybody  post a snippet to show me what goes where?
Appreciate it.
Windows 7 x64
Weather PC: Intel NUC
Davis Vantage Pro 2
Weather Underground: KPAYORK30
York, PA Weather (Saratoga)
York, PA Weather (Leuven)
York, PA PWS Station
Offline ValentineWeather
« Reply #151 on: November 06, 2017, 10:41:57 PM »
Appreciate it.
I use this, I'll include the top 2 lines also.
</item>
<item caption="Radar/Satellite">
  <item caption="Local and US Radar" link="wxusradars-hanis3.php" title="NOAA Ridge Radar"/>
Randy
Offline W3DRM
    • Emmett Weather
« Reply #152 on: November 06, 2017, 10:49:51 PM »
I'm running the wxusradars-hanis3.php and its working. Version 5 (20170122)
Thanks Randy, however, I must have something setup wrong as I only see radar data for the last map frame. All other frames show only the map and no radar return data. I suspect there may be some kind of error causing this but I don't know enough about the code to troubleshoot it myself. I see this condition on any of the maps so it must be something pretty basic.
--- RIPE Atlas Probe - 32849
« Reply #153 on: November 06, 2017, 11:04:45 PM »
I can't help either. If you haven't already download the new scripts on previous page again. Go back and read instructions again. I know some errors were corrected and you may have one that isn't.
Randy
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #154 on: November 06, 2017, 11:50:31 PM »
I know this is an older thread but I've just noticed that my radars are only displaying returns on the last frame. I seem to remember this being mentioned as a problem quite some time ago but I don't remember what the resolution, if any, was for the issue. Can someone please help refresh my memory on this? I am running the latest version of the wxusradars-hanis.zip script (20170427).
You're not running all of the latest scripts, Don.  Here is your problem script.  You can get the scripts from my site: main saratoga template script, includes script, and the radar display script. (As usual, right-click and 'Save as...' a php file rather than a text file.) The ONLY place you need to modify the settings is in the main script.  The setting parameters in the other two scripts are to allow stand-alone debugging.
I would suggest saving all three of the latest scripts while updating HAniS to at least Version 3.9 which changes are incorporated into this version of the radar script.  Attached is the Version from July 17, 2017.
« Last Edit: November 07, 2017, 02:45:47 PM by gwwilk »
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline W3DRM
    • Emmett Weather
« Reply #155 on: November 07, 2017, 12:33:29 AM »
I would suggest saving all three of the latest scripts while updating HAniS to at least Version 3.9 which changes are incorporated into this version of the radar script.  Attached is Version 4.6
THANK YOU Jerry!!! It's just amazing how some current code makes things magically work again! I uploaded all of the files you mentioned and updated to HAniS 4.6. Guess I didn't have the right mix of code and couldn't figure out where to go next.
Again, thanks for the help - that's what I love about this forum. There is always someone ready to lend a hand to those of us who are challenged...
Offline mldenison
    • York, PA Weather
« Reply #156 on: November 07, 2017, 07:52:23 AM »
</item>
I appreciate it.  That's what I had in my flyout menu but it's not working: https://www.m82a1.us/wxusradars-hanis3.php
I'm guessing it's a setting in one of the files?  I believe I have the latest files uploaded.
« Last Edit: November 07, 2017, 07:58:53 AM by mldenison »
Windows 7 x64
Davis Vantage Pro 2
« Reply #157 on: November 07, 2017, 08:04:16 AM »
Go to Jerry's post above #154 and download all the files needed and install, you probably have something missing.
Randy
Offline gwwilk
« Reply #158 on: November 07, 2017, 08:47:26 AM »
Also, see this post in this thread...
Save this snippet
<?php phpinfo(); ?>as 'phptest.php' and place it on your site.  It will tell you the status of your site's php and php.ini file when you run it.
gwwilk@gmail.com
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #159 on: November 07, 2017, 11:05:43 AM »
Jerry,
Well, this isn't nice. Updated from v5 (working) to v5a (now not working) and the new hanis (4.6?) using your links above. Comes up but blue 'loading images' bar stops at varying progress marks and the images do not appear. By putting back the previous hanis things work fine. http://tiggrweather.net/wxusradars-hanis3.php
FYI but thoughts appreciated.
W7JKG
« Reply #160 on: November 07, 2017, 11:12:37 AM »
Interesting. I never did the latest update because mine was working also.
Randy
Offline jgillett
« Reply #161 on: November 07, 2017, 11:22:24 AM »
After all this time one would think I had learned to leave things alone!
W7JKG
Offline mldenison
    • York, PA Weather
« Reply #162 on: November 07, 2017, 11:28:27 AM »
That did the trick.
I got the freezing as others have gotten (above) and fixed that with the earlier hanis js files.
I appreciate the help!
Windows 7 x64
Davis Vantage Pro 2
Offline mldenison
    • York, PA Weather
« Reply #163 on: November 07, 2017, 11:44:57 AM »
Save this snippet
And thanks for this.  It alleviated a call to GoDaddy about the fopen setting!
« Last Edit: November 07, 2017, 02:59:45 PM by mldenison »
Windows 7 x64
Davis Vantage Pro 2
Offline gwwilk
« Reply #164 on: November 07, 2017, 02:46:06 PM »
I left for the funeral of a nurse-colleague of many years at 10 AM, and just now returned, so I've been out of the loop.
I will replace the latest HAniS version with the one I'm using from July 7, 2017.  I don't know the version number and Tom Whitaker's HAniS site doesn't list the dates of the versions.
Sorry about putting up a version untested by me. :oops:
« Last Edit: November 07, 2017, 02:51:18 PM by gwwilk »
gwwilk@gmail.com
Offline gwwilk
« Reply #165 on: November 07, 2017, 02:56:13 PM »
One other thing I should mention.  You can set up this script to run 'stand alone' by setting in the main script Settings
$standAlone = false; // false if we run in the template environment
to
$standAlone = true; // false if we run in the template environment
.  It's called 'wxusradars-hanis3-SA.php' on my site.  Ergo, no template is then needed to run the scripts.
gwwilk@gmail.com
Offline jgillett
« Reply #166 on: November 07, 2017, 03:23:44 PM »
Not a problem in my book, Jerry, and no disrespect intended, but since whatever version I reverted to is running without problem I'll just stay with it. "If it ain't broke...".
W7JKG
Offline W3DRM
    • Emmett Weather
« Reply #167 on: November 08, 2017, 01:02:16 AM »
Jerry,
My version is now hanging. Where do I find the July 7, 2017 version of the HAniS code? I'm running the July 17, 2017 version at the moment.
Offline gwwilk
« Reply #168 on: November 08, 2017, 07:46:13 AM »
Jerry,
That's the version I'm running, 20170717 (YMD because that's the only way to get a useful sort of a series of files that incorporate dates).
Not only is this script hanging on your site, but it's crashing my browser, Chrome, right now.  Something else appears to be going on here.  I would re-upload all three of the scripts along with the HAniS directory.
gwwilk@gmail.com
« Reply #169 on: December 01, 2017, 11:39:26 PM »
Mine isn't working:  https://stillwaterweather.com/wx/wxusradars-hanis3.php
Using version 5 and checked phptest.
« Last Edit: December 01, 2017, 11:51:10 PM by Bunty »
Offline mkutche
    • GosportWx.com
« Reply #170 on: December 02, 2017, 12:03:07 AM »
mine seems to work.. http://gosportwx.com/wxusradars-hanis3.php although every now and then I keep getting undefined offsets on line 158 of radar-status.php
Mike K.
Davis Vantage Vue 6250 - CumulusMX (3.21.1-b3205)
Gosport, Indiana
Gosportwx.com twitter.com/GosportINWX
Offline jgillett
« Reply #171 on: December 02, 2017, 12:16:32 AM »
Mine still working. See http://www.wxforum.net/index.php?topic=27077.msg335874#msg335874 re: my backing down the hanis file one version.
« Last Edit: December 02, 2017, 12:18:21 AM by jgillett »
W7JKG
« Reply #172 on: December 02, 2017, 04:36:32 AM »
Oops, sorry. My initial install must have gone bad.  I reinstalled it and all is fine now!
A look at my stand alone version:  https://stillwaterweather.com/usradars
« Last Edit: December 02, 2017, 05:39:15 AM by Bunty »
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
« Reply #173 on: December 03, 2017, 02:15:30 PM »
I got the radar script up and running,  but the zoom button doesn't seem to do anything.  Did i miss something?
https://www.northbendweather.com/wxradar.php
Software: WeatherDisplay
Offline gwwilk
« Reply #174 on: December 03, 2017, 02:23:40 PM »
Zooming in HAniS is a two-step process.  Click 'Zoom' and then click on the map where you want to see it enlarged.  Repeat clicking on the map as necessary/desired.
« Last Edit: December 03, 2017, 02:30:03 PM by gwwilk »
gwwilk@gmail.com
