This is just a safety thing even if you have a main breaker go bad to replace it you need to turn off the main breakers before you pull the meter to replace the breakers and when you got the new breaker in place you have to leave them in the off position until you replace the meter. Other wise if for some reason there is a call for electricity in the house (water heater, furnace, electric stove, air, well pump, or the like) you will probably not like the results when you try an push the meter back in place.
Don't be messing around inside the meter box trying to add wire in that box... And don't be messing around with the main breaker with out removing the electric meter..
