In the process of changing laptops, I had my VP2 console power source unplugged from the wall and changed the batteries. When I put it all back together, I ended up with no data being displayed for wind, outside temp, or outside humidity, with "----" where there should be numbers.
Incidentally, I'm getting a blinking "X" in the LR corner (indicating data received), with the proper station number also being reported.
BTW, if I step thru the TEMP button, the current outside temp shows up where you normally read inside temp. Where in heck did I go wrong? It appears the console is receiving valid outside data, it's just not displaying it.
