Author Topic: Once again lets make your website a better user experience  (Read 1763 times)
Offline wvdkuil
  • Wim van der kuil
    • Support site Leuven Template and scripts
Re: Once again lets make your website a better user experience
« Reply #25 on: August 25, 2017, 07:40:32 AM »
Now that I have modified my .htaccess file to "cache" these files, where can I check to see if they are really being cached to my local machine rather than retrieving from file server?
Jim
Go to your website , example below is Chrome
Right Click somewhere in the heading, choose inspect
Bottom part changes
Hit the refresh page in the address area (round arrow)
In the bottom part you can now see  if the files come from your server, memory cache, disk cache a.s.o.
The attached screen-shot shows that Chrome is loading most parts of your page from the cache.
P.s. you can see errors on your pages when you click  the console-tab
« Last Edit: August 25, 2017, 07:42:33 AM by wvdkuil »
Vantage VUE with a WLIP connected to a Meteobridge used for https://weer.sluispark.be/
Same VUE+WLIP uploads to WL.com(2.0)  used for https://sluispark.be/weather28/
Vantage VP2 with a USB logger/Meteobridge for https://www.weerstation-herent.be/
Envoy with a WLIP uploads to WL.com(1.0) as a backup / test for the same site.
Offline SoMDWx
    • Southern Maryland Weather
« Reply #26 on: August 25, 2017, 07:50:41 AM »
Awesome! Looks like its working...
thanks for all your inputs...
Jim
Jim Wyman
http://somdweather.com
http://scit.somdweather.com
  • Home of Oklahoma State University
« Reply #27 on: September 06, 2017, 01:59:28 PM »
good info here..
Is there a way to cache certain files with wildcards? I.E, I have a menu system with GIFS that will ALWAY be used and could be cached. The GIF names are:
Jim
if your confident and understand the .htaccess  file and its consequences when it goes wrong ..
#30 days
<Files “somdwx_m1bg0.gif”>
  ExpiresActive On
  ExpiresDefault A2592000
</Files>
#1 year 365 days
  ExpiresActive On
  ExpiresDefault A31536000
</Files>
it is best to do some research ..
brian..
Is there a more efficient way to specify more than one image so that </Files> only has to be used once?  Let's not let the browser read the .htaccess longer than necessary.
Also the 2nd home page using modified AltDashboard 6.81 at http://stillwaterweather.com/wx/2ndhome.php
Offline SoMDWx
« Reply #28 on: September 06, 2017, 02:20:58 PM »
yes. can use wildcards...
Jim Wyman
« Reply #29 on: September 27, 2017, 12:07:58 AM »
I don't understand how to do wildcards as well as some of the other operations.  I did speed up my front page to some extent by switching to a web cam source that does still, rather than moving images.  For the source code, I updated ancient attributes to get it compliant with HTML5.   Some tables had to go and were converted to div.  It slimmed things down some for a little greater speed.  Getting rid of cellspacing and cellpadding attributes helped.  Some experts say all tables should go and use div, instead, even for tabular data.  But important to learn CSS and DIV coding for that.
For gtmetrix, I'm still well down from the 90s.  But don't understand how to do the more arcane stuff, such as how to make a cookieless domain, css sprites and avoid URL redirects.   But fully loaded time on my front page can be as little as 2.1s.  Around 1s would be preferable but surely difficult for well detailed weather pages.
Offline SoMDWx
« Reply #30 on: November 13, 2017, 01:56:29 PM »
Hi All,
 I have implemented the cache control directive in my .htaccess file but some of the images are still not being cached.
<IfModule mod_expires.c>
    ExpiresActive On
    ExpiresByType text/css "access 1 week"
    ExpiresByType text/html "access 1 week"
    ExpiresByType application/pdf "access 1 month"
    ExpiresByType text/x-javascript "access 1 week"
    ExpiresByType application/x-shockwave-flash "access 1 month"
    ExpiresByType image/x-icon "access 1 year"
   <FilesMatch "\somd_banner.png$">
    ExpiresActive On
    ExpiresByType image/png "access plus 1 year"
   </FilesMatch>
   <FilesMatch "\mail.png$">
    ExpiresActive On
   </FilesMatch>
   <FilesMatch "\Twitter.png$">
    ExpiresActive On
   </FilesMatch>
   <FilesMatch "\Facebook.png$">
    ExpiresActive On
   </FilesMatch>
   <FilesMatch "\adbanner.png$">
    ExpiresActive On
   </FilesMatch>
   <FilesMatch "\school-bus-1.jpg$">
    ExpiresActive On
    ExpiresByType image/jpeg "access plus 1 year"
   </FilesMatch>
   <FilesMatch "\wrn1.jpg$">
    ExpiresActive On
   </FilesMatch>
   <FilesMatch "\winter_weather.jpg$">
    ExpiresActive On
   </FilesMatch>
  # Compress HTML, CSS, JavaScript, Text, XML and fonts
  AddOutputFilterByType DEFLATE application/javascript
  AddOutputFilterByType DEFLATE application/rss+xml
  AddOutputFilterByType DEFLATE application/vnd.ms-fontobject
  AddOutputFilterByType DEFLATE application/x-font
  AddOutputFilterByType DEFLATE application/x-font-opentype
  AddOutputFilterByType DEFLATE application/x-font-otf
  AddOutputFilterByType DEFLATE application/x-font-truetype
  AddOutputFilterByType DEFLATE application/x-font-ttf
  AddOutputFilterByType DEFLATE application/x-javascript
  AddOutputFilterByType DEFLATE application/xhtml+xml
  AddOutputFilterByType DEFLATE application/xml
  AddOutputFilterByType DEFLATE font/opentype
  AddOutputFilterByType DEFLATE font/otf
  AddOutputFilterByType DEFLATE font/ttf
  AddOutputFilterByType DEFLATE image/svg+xml
  AddOutputFilterByType DEFLATE image/x-icon
  AddOutputFilterByType DEFLATE text/css
  AddOutputFilterByType DEFLATE text/html
  AddOutputFilterByType DEFLATE text/javascript
  AddOutputFilterByType DEFLATE text/plain
  AddOutputFilterByType DEFLATE text/xml
  # Remove browser bugs (only needed for really old browsers)
  BrowserMatch ^Mozilla/4 gzip-only-text/html
  BrowserMatch ^Mozilla/4\.0[678] no-gzip
  BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
  Header append Vary User-Agent
</IfModule>
Jim Wyman
Offline weatherist34
  • its just my hobby
    • Sinanoba Istanbul Home Weather Station
« Reply #31 on: November 13, 2017, 04:08:33 PM »
check  IfModule mod_expires.c is present and if it has something like below it could be overriding any specific individual files your try to cache
ExpiresByType image/gif A604800
ExpiresByType image/png A604800
ExpiresByType image/jpeg A604800
can you explain <FilesMatch "\winter_weather.jpg$"> the dollar character purpose at the end of the jpg etc not seen this b4 so i may learn something new
simplified your
<Files "somd_banner.png">
  ExpiresActive On
  ExpiresDefault A31556952
</Files>
examples    A(value) is seconds
ExpiresDefault A2592000 = 1 month
ExpiresDefault A604800= 1 week
ExpiresDefault A86400 =1 day
ExpiresDefault A60 = 60 seconds
unfortunately i dont use the specific image method so you may have to go through a bit of trial and error . i just cache the file extensions like svg etc..
brian
Offline SoMDWx
« Reply #32 on: November 13, 2017, 05:00:40 PM »
The "$" tells that it's and EOL (end of line).
Jim
Jim Wyman
Offline SoMDWx
« Reply #33 on: November 14, 2017, 11:16:24 AM »
Is there a way to cache anything out of one specific directory.
I.E., all the forecast images could be cached..  "/forecast/images/*.jpg"
Jim
Jim Wyman
Offline Toxic
  • #conligwx
    • conligwx.org
« Reply #34 on: November 14, 2017, 06:47:48 PM »
Jim
if your running PHP 7 you may also have zend opcache running.
you can then blacklist files from being cached too.
Regards Simon
  • its just my hobby
« Reply #35 on: November 15, 2017, 06:25:57 AM »
i guess the other way would be create a separate htaccess file and place it in the image folder you wish to cache . just have a limited functional htccess for that folder. try it see no reason why it wouldnt work and it will cache that file with the values you added. trial and error ..
<IfModule mod_headers.c>
    #Header set Cache-Control "max-age=31536000"
    Header unset Cache-Control
    Header unset ETag
    FileETag none
</IfModule>
    ExpiresActive On
    ExpiresDefault "now"
       <Files "/path/imagefolder/*.jpg">
      ExpiresDefault "access plus 1 month"
    </Files>
</IfModule>
