yes I have
I also have some errors into my template Saratoga but that I have fix
only the problem with this script I can not fix
so I hope someone know what to do
for info I was run V2 from this script and after the update from my server to PHP 5.5 I saw the error
Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead inso I have delete that script and download the new one Whos Online V3 but also this one have the some problem
so I hope for you that your server will not update the PHP to 5.5 if do you will have the some problems like my
Greetings Gert
Does PHP work?
Yes, it does. PHP Version 5.5.17
To run the WXGRAPHIC script, you need GD enabled in PHP.
Current GD status:
•GD support: yes
•GD Version: bundled (2.1.0 compatible)
•FreeType Support: yes
•FreeType Linkage: with freetype
•T1Lib Support: no
•GIF Read Support: yes
•GIF Create Support: yes
•JPEG Support: yes
•PNG Support: yes
•WBMP Support: yes
•XPM Support: yes
•XBM Support: yes
•JIS-mapped Japanese Font Support: no
If you don't see "Yes, it does." in large font above, then PHP is not enabled.
Are you sure you have php 5.5?
I've Php 5.4 but i think the problem is in these two versions (5.4/5.5).
