Author Topic: Solar Panel  (Read 2118 times)
Solar Panel
« on: April 18, 2016, 09:10:11 PM »
When I received the station I charged up the battery. It topped out at 2653mv. I mounted the unit hooked up the solar panel on Saturday and every day the voltage is on a steady decline.
It's now down to 2605mv. We have had just about full sun the past 2 days and the panel is facing SW.
Any idea's why the panel isn't charging the battery?
Offline SpringHillWeather
  • Weather Hobbyist
  • Spring Hill, Florida
    • Spring Hill
Re: Solar Panel
« Reply #1 on: April 18, 2016, 09:38:59 PM »
If you login to your BloomSky dashboard http://dashboard.bloomsky.com and then Click -->Data View-->Station Status and check the graph.  This might help determine if its charging or not.
Here is mine:
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Ambient 1001 | ObserverIP | Meteobridge | MeteoPlug
Re: Solar Panel
« Reply #2 on: April 18, 2016, 10:22:03 PM »
It's not charging. That's the issue.
It's been on a slow decline since the initial charge.
Other then plugging it into the unit is there another step that's involved?
  • Weather Hobbyist
    • Spring Hill
Re: Solar Panel
« Reply #3 on: April 18, 2016, 10:34:31 PM »
Other than plugging it in there there aren't any other steps.  However I do believe if the battery isn't low enough it won't charge.
What about the a/c charger?   The Bloomsky will light up with a Red led when charging.
Here is a similar issue on the Bloomsky support site: https://bloomsky.desk.com/customer/portal/questions/16251585-not-sure-if-device-is-getting-charged
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Offline RainmanWeather
    • RainmanWeather
Re: Solar Panel
« Reply #4 on: April 18, 2016, 10:34:39 PM »
It might be OK, here is a view of mine. It sometimes sits down for several days like SIW shows and then jumps way back up and to the steady decline again like you are experiencing. I would wait it out a little longer to see what happens.
  • Weather Hobbyist
    • Spring Hill
Re: Solar Panel
« Reply #5 on: April 18, 2016, 10:42:27 PM »
I think your right the charging threshold looks to be around 2600mv.
I checked my battery table and once it went down to 2595mv, it started to charge.
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Re: Solar Panel
« Reply #6 on: April 18, 2016, 10:47:26 PM »
Thanks guys. It's almost at that threshold now so we'll see what happens.
Offline W3DRM
    • Emmett Weather
Re: Solar Panel
« Reply #7 on: April 20, 2016, 11:06:15 AM »
These graphs are interesting. Here is what I see on mine. Can't explain why they look like they do because we have have pretty much all sunny weather lately. Mine look very much like RainmanWeather's.
--- RIPE Atlas Probe - 32849
Re: Solar Panel
« Reply #8 on: April 28, 2016, 07:53:56 PM »
That was the issue. it's been charging every day since then.
  • Weather Hobbyist
    • Spring Hill
Re: Solar Panel
« Reply #9 on: April 29, 2016, 12:20:51 AM »
Good news, thanks for the update.
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
